72 Door panel install help please
Anyone have a sketch or drawing showing how the handle and crank pieces go in a 72 door? When I got my truck it had no interior. Wondering if I need foam spacers, springs or plastic washers & I see the plastic panels have an escutcheon on them.
Re: 72 Door panel install help please
Here is what I found in my factory assembly manual. Is this what you were looking for?
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" |
Thanks I looked at that too. But 72 has plastic door panels.
One of the First
![]() Join Date: Jan 2000
Go LMC website and look at there 67-72 parts catalog. Its great for installs.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
![]() Join Date: Jun 2007
You said you needed help installing the door and window cranks and associated parts. The way those parts mount is the same from 1967 to 1972. The 1972 door handle and window crank stub out sticks out slightly further to accommodate those plastic door panels. But everything works the same otherwise.
Those pictures should help you with the assembly except for the installation of the door panel which in 72 is held on by plastic clips.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
Other than the handle clips there is nothing else involved . At least that’s the way my truck is .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
Ok good to know. Thanks Guys.
+1 on post #6. With that said IDK if originally there were any plastic stepped washers for the window cranks pn my 72 C10 like my 67 Camaro has. Given the door panels are hard plastic
...but the illustration post in # 2 shows item "7" goes between panel and window & door handle...so that may be the plastic washer thing similar to what my 67 Camaro uses...if not the same |
Follow this link on the forum. 72 panel is toward the end. Only 1090 pages!
A big thank you to CS1972 for posting this manual. https://67-72chevytrucks.com/vboard/...d.php?t=833705 |
![]() ![]() Join Date: Sep 2008
72 has a thick foam washer between the door and the door panel.
#11 | |
these say 60-66 https://www.cjponyparts.com/gasket-s...-1966/p/IHSG1/ and these for 67-72 https://www.amazon.com/dp/B07S5CXZCB...v_ov_lig_dp_it |
I am no expert, I'm just the guy asking questions. But, what I think I have figured out is the 72's do not use the escutcheon. Just the plastic stepped washer. If you have wood grain panels then the foam goes in between the panel and the wood grain part.
The foam washer goes over the crank stud, then the panel goes on, then the stepped plastic washer, then the handle. The wood grain is held to the panel by the stainless trim. Nothing goes between the panel and the woodgrain.
#15 |
davischevy is correct. Don't rely on aftermarket parts catalogs for correct information. I've found several errors in every catalog
#16 |
![]() ![]() Join Date: Feb 2009
I can't speak too much for 72. The escutcheons differ from 71, same perhaps the flush washers. Seems there's a plastic washer or two.
You might contact Wes at Classic Heartbeat, he knows the doors for certain and can get the parts.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too. Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc. The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#17 |
![]() Join Date: May 2003
I believe these are what your looking for.
Gary https://www.classicindustries.com/pr.../20393850.html
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
#18 |
Dorman makes them, Amazon has them
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
| Bookmarks |
