Old 08-07-2004, 10:22 PM   #1
Chevelle454
Chevelle454's Avatar
Desktop Dyno?
Is there a program that will estimate the horsepower and torque of your engine if you give it all the specs? If so what is it called, and can I get it for free? If one of you has the program(if it exists), can you see what this would be? :
---1972 Chevy 350 2 Bolt Main---
-Bored to .030 over(355)
-Crane Energizer Cam & Lifter
Adv Dur Int 266 Exh 266 Dur @ .050
Int 210 Exh 210 Deg Lobe Sep 110
Valve Lift Int .440 Exh .440
-Cloyes Double Roller 3 Key-way timing set
--Hypereutectic Pistons
-Moly Rings
-Edelbrock 600cfm electric choke carb
-Edelbrock Performer Intake
-Hedman Hedders
This should be a pretty average setup. What do you think I've got? 300hp maybe?
1972 C10
1972 C20
Chevelle454 is offline   Reply With Quote
Old 08-07-2004, 10:28 PM   #2
toddtheodd
The oddest Todd around
toddtheodd's Avatar
I think you'll also need to know the specs on your heads as well.
Todd
toddtheodd is offline   Reply With Quote
Old 08-07-2004, 10:31 PM   #3
mocwon
Keep On Truckin'
mocwon's Avatar
The Desktop Dyno is not real accurate from everyone I have talked to. I had a copy several years ago and ran the numbers for my Muskrat through it and came out with numbers that were insanely high.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 08-07-2004, 10:36 PM   #4
Chevelle454
I'm not sure exactly with the heads. All I know is that they are the stock heads on a 1972 350 from a C20 with a 2bbl carb on it.
1972 C10
1972 C20
Old 08-07-2004, 10:50 PM   #5
7gmc2
7gmc2's Avatar
hey chevelle454 check your private messages
1972 GMC Sierra Grande
7gmc2 is offline   Reply With Quote
Old 08-07-2004, 11:27 PM   #6
jhow66
jhow66's Avatar
Desktop Dyno 2000
Stock heads-headers thru mufflers-guessing 8.5to1 ratio.
HP@ flywheel---------Torque@ flywheel
RPM
2000---136-------------357
3000---205-------------358
4000---264-------------347
4500---270-------------315
5000---254-------------267
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
