#3451 |
![]() Join Date: May 2006
Re: PO has me PO'd
Thanks for the replies, just wondering who might find my build interesting.......after 23 years
#3452 |
Too Dumb To Know Better
Re: PO has me PO'd
![]() You are better off than most. |
#3453 |
Re: PO has me PO'd
Thanks Bud for the encouragement, just out of money for the project.Good analogy......
![]() Don't use your veneers to scribe lines, call me weird, but I like the smell of Dycom Had to hammer out the crease in the metal
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-09-2022 at 11:17 AM. |
#3454 |
![]() Join Date: Mar 2011
Re: PO has me PO'd
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#3455 |
Re: PO has me PO'd
![]() In theory this system should work, just have to adapt to work bench, applications of materials leaves a little bit.to be desired ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-12-2022 at 10:01 AM. |
#3456 |
Re: PO has me PO'd
#3457 |
Re: PO has me PO'd
![]() Just have to build a return......degrees? Should have to mentioned yesterday but, thanks to all the veterans out there for their service, sacrifice And my ability to live is this great country we call the US of A BELATED VETERANS DAY
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-12-2022 at 10:58 AM. |
#3458 |
Re: PO has me PO'd
![]() Seems the return is 165 degrees, so I have to make a pie cut that size
#3459 | |
![]() ![]() Join Date: Mar 2016
![]() Quote:
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() |
#3460 |
BlahBlahBlah
Re: PO has me PO'd
Ive never owned a Blazer but I learn a lot from watching the Blazer builds. I don't comment much, but do go through the build section every day to make sure I don't miss something.
#3461 |
Re: PO has me PO'd
![]() Seems to be 7 degrees ÷or - of 90
#3462 |
Re: PO has me PO'd
![]() A little more fine tuning, and this piece should be ready for clecos, I may flange the top, where the magnet is Guys thanks for posting up, gives more confidence to continue on
#3463 |
Re: PO has me PO'd
![]() If you can't weld, bolt...........
#3464 |
Re: PO has me PO'd
![]() If you can't weld, bolt........ Of course 1 walked, even center punched
#3465 |
Re: PO has me PO'd
![]() Tired of having your center punch roll away? Wrap some waxed thread around it It was in a neighbors Kennedy box i bought for 50.00 when he passed
#3466 |
Re: PO has me PO'd
#3467 |
Re: PO has me PO'd
![]() 6-32 82 degrees counter sunk
#3468 |
Re: PO has me PO'd
![]() Need to build piece at top
#3469 |
Re: PO has me PO'd
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-11-2022 at 06:10 PM. |
#3470 |
Re: PO has me PO'd
![]() 2 pie cuts Getting closer, just have to get top and bottom pieces to fit together
#3471 |
Re: PO has me PO'd
#3472 |
![]() Join Date: Nov 2007
Re: PO has me PO'd
Not much chatter in the Blazer build section here. Keep pushing forward! Looking good, sir!
#3473 |
Re: PO has me PO'd
Thanks AJ, I guess when your build takes 22 years, people run out of things to say,lol.
Sounds like you have alot of new things in your life now, congrats on all of them, looking forward to hearing about your frame build, quite the undertaking
#3474 |
Re: PO has me PO'd
#3475 |
Re: PO has me PO'd
![]() So the process works, next time I will use panel bond and rivets
