L83/L86/LT swap - what A/C compressor?
I am going to put a Vintage air on my L83 in my truck. I have instructions on how to modify the existing A/C compressor to remove the variable displacement and you can run it with the Vintage air.
However, I met a guy at a cruise-in and he said he used this method and the A/C compressor last about 1 year before it burns up. Anybody running the factory mounting and able to modify the bracketry or compressor enough to mount something like a Sanden off an LS ? |
#2 | |
BMW & ASE Master Certified
Re: L83/L86/LT swap - what A/C compressor?
Ive been running stock gen5 compressor with the factory solenoid valve tied into the compressor clutch for 4+ years zero problems, 2 other builds, no problems. 2 of them use the a/c can bus module to turn them on. 1 with stock 1987 a/c on power, and 1 with vintage air ground signal input to module (that turns on a/c) both work exactly the same, normal. clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
#3 | |
Thanks! |
| Bookmarks |
