Old 12-10-2022, 06:34 PM   #1
riz
LS upper radiator neck on water pump....
does the upper radiator hose neck on the top off the water pump interfere with the throttle body actuation?
If so, how do you get around it/ fix it?
I'm thinking using either the Summit or Holley fabricated intake and 92mm throttle body.
RIZ
RIZ
81 C10 short box
82 K5 Blazer
riz is offline   Reply With Quote
Old 12-11-2022, 06:19 PM   #2
LS short box
Re: LS upper radiator neck on water pump....
Pick of my 98 wrangler with DBC. Truck FEA. Truck intake.
Pick of my Nova with DBC. 2002 Camaro FEA. LS6 intake.
I would buy LS "style" radiator with the inlet and outlet on the passenger side of the radiator. Makes routing the intake tube easier.
Pic of my latest 80 Camaro project.
Old 12-21-2022, 06:02 PM   #3
6600DURAMAX
6600DURAMAX's Avatar
LS Short Box - on you Camaro can you supply the part numbers for the rubber 90 and then the aluminum tube ? Super clean setup
thanks
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio .....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 12-21-2022, 10:31 PM   #4
LS short box
I don't have the part numbers but on my LS swaps I buy intake stuff from intakehoses.com. They have a huge selection.
The Camaro has a blade style mass air flow sensor because it's a LS3 that you can't see on the bottom of the intake tube.
Pic of my 68 C10 intake. The engine is a 2002 LS6 so it has a mass air sensor right after the air cleaner. It's kind of like right behind the radiator cap.
