Old 12-20-2022, 06:41 PM   #3501
gferris5
gferris5's Avatar
Re: What did you do to your truck today.The 3rd chapter
Finally finished my internally regulated alternator swap! I put a bus bar on the core support and ran an 8ga cable to the other junction, cleaned out a bunch of old bad wiring, then redid a bunch of grounds and added a better thicker ground cable from the block to the frame. Now even though the battery is in the bed, it has 14.4 volts with lights and wipers on and the battery ammeter still works. Maybe not a big deal for many folks, but this was a victory for me! So stoked!
Have mercy, I'm recovering from my 4x4 addiction.
gferris5 is offline   Reply With Quote
Old 12-22-2022, 08:18 AM   #3502
Nick2x2x
Nick2x2x's Avatar
Well in August I bought my wife a truck 72 short bed going to be a stepside! sooo i have been slowly working on it. So i replaced the center part of the dash since someone cut it and put in a double din set up we wanted it factory. I started to lay out the wiring harness so i can have it really clean under the dash. The green truck was my grandfathers I did a frame off on a few years back with information from all of you here on this site.
Nick2x2x is offline   Reply With Quote
Old 12-26-2022, 04:21 PM   #3503
68bowtie
68bowtie's Avatar
Finally finished my red interior conversion…
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Thank you all so far you are angels!!
68bowtie is online now   Reply With Quote
Old 12-26-2022, 06:50 PM   #3504
best view
That’s a hard combo to beat
best view is offline   Reply With Quote
Old 12-26-2022, 08:34 PM   #3505
pjmoreland
pjmoreland's Avatar
Wow!!
pjmoreland is offline   Reply With Quote
Old 12-26-2022, 10:35 PM   #3506
68bowtie
68bowtie's Avatar
Originally Posted by pjmoreland View Post
Wow!!
I just wish the body was nice enough to match it
Old 12-27-2022, 12:04 AM   #3507
allchevy58
allchevy58's Avatar
Attachment 2243354
Sharp! Good work.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 12-27-2022, 01:07 AM   #3508
towbar
towbar's Avatar
Location: Marshall, NC....heart of the Appalachians.....aka, Gods country!!
inner rocker panel replaced, kick panel replaced, A post repaired , cab corner cut out, new one fitted and ready to weld, inner door bottom replaced, outer lower door skin replaced...still need to fit the outer rocker, replace door to align rocker and cab corner before final welding. Gap the door, then ready for body work. Hopefully will get some of that finished this week
towbar is offline   Reply With Quote
Old 12-28-2022, 01:37 AM   #3509
pjmoreland
pjmoreland's Avatar
I've been working on improving the u-joint angles on my two-piece driveshaft. I discovered that the center support was quite loose, despite the fact that it is only about a year old and has just a couple thousand miles on it. A local driveline shop rebuilt the driveshaft and installed a new center support. I'm not sure what the brand is of that one, but I ended up replacing it with a Federal Mogul/Bower/BCA unit that was made in the USA. Here's a video that compares the two center supports.
https://youtu.be/f6VOjeShS-A
Old 12-28-2022, 11:26 PM   #3510
towbar
towbar's Avatar
removed the matching numbers 44k original mile 350 from the 72, full tear down and inspected the entire engine...bearings good and resuable, new oil pump, timing chain, Comp Cam 268, Lunati cam saver lifters, all new gaskets, seals, 1 piece oil pan gasket.
cleaned and sprayed epoxy primer on the engine, followed by single stage hugger orange color...think it turned out good....engine is back in the truck and running well now. Cant wait to put some miles on the ol girl.
Old 12-29-2022, 07:57 AM   #3511
K10-Kansas
K10-Kansas's Avatar
I pulled the remaining wires. Cut the new firewall bulkhead hole, and mounted the bulkhead. Today, I'll start running new wires.
K10-Kansas is offline   Reply With Quote
Old 12-29-2022, 11:25 AM   #3512
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Attachment 2243354
I love it!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 12-30-2022, 12:57 AM   #3513
Sheepdip
Sheepdip's Avatar
Attachment 2243354
That's way, way too purdy to sit in, let alone spill beer on!
Sheepdip is offline   Reply With Quote
Old 12-30-2022, 02:30 PM   #3514
tdangle
tdangle's Avatar
Got some color on the roof, and installed new glass. Still a lot to do
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 12-31-2022, 05:41 PM   #3515
KQQL IT
At the body shop.
KQQL IT's Avatar
New delco for old delco plug wires.
Amazing the difference.
Always thought that old blue just hated the rain, turns out just the wires didn't.
New truck
Old 01-02-2023, 05:54 PM   #3516
72c20customcamper
72c20customcamper's Avatar
Took out the 72 to get some diesel for the Kubota. Nice day and we had rain last few days so whatever salt was in the road was washed away . But because we’re in the NYC reservoir watershed they can’t use much salt on the road .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 01-03-2023, 10:06 PM   #3517
Johnl48
Did some wet sanding and polishing today
Old 01-03-2023, 10:58 PM   #3518
Steeveedee
Who Changed This?
Steeveedee's Avatar
Sweet!
~Steven
Simi Valley, CA
Old 01-05-2023, 08:28 PM   #3519
Fastgramps
Added some bling (bumper guards) to my front bumper🤙
Fastgramps is offline   Reply With Quote
Old 01-05-2023, 08:30 PM   #3520
Fastgramps
Forgot to add the pic☺️
Old 01-06-2023, 12:51 AM   #3521
Sheepdip
Sheepdip's Avatar
Nice looking DRW Flatbed Fastgramps.
Old 01-08-2023, 04:07 PM   #3522
KQQL IT
At the body shop.
KQQL IT's Avatar
2 gallons of 15-40 rotella
And one wix 51794
A fresh tube of grease thru the zerks.
Should be good for another year.
11 miles a week ads up.
Old 01-08-2023, 09:13 PM   #3523
zicc1835
zicc1835's Avatar
nice......
zicc1835 is offline   Reply With Quote
Old 01-08-2023, 09:16 PM   #3524
zicc1835
zicc1835's Avatar
love the color.....
Old 01-08-2023, 09:21 PM   #3525
zicc1835
zicc1835's Avatar
delete.........finished getting those secured
