Old 12-30-2022, 10:22 AM   #1
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
LS PS and 71 steering gear
Wanting to make sure I don't overpressure the old steering box with the 5.3 PS pump...
How many shims do I need in the pump? I ask this way because I don't have a pressure gauge setup for this, but I can count to six or so. Thanks.
Loren
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 12-30-2022, 10:36 AM   #2
cj847
cj847's Avatar
Re: LS PS and 71 steering gear
I would suggest you hook it up and see. I doubt you will over pressure it. It would be hard to tell anyway as from factory there was little road feel anyway. The only time I would use shims is if you had rack and pinion.
I am actually having the opposite problem. I'm beginning to think it is my box. I will know in about a week when I put another new pump on.
http://67-72chevytrucks.com/vboard/s...d.php?t=840389
cj847 is offline   Reply With Quote
Old 12-30-2022, 11:34 AM   #3
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I'm running the 71 steering gear with the LS pump and hydro boost and the gearbox is fine as is.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 12-30-2022, 12:05 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Loren
I have been running the '76 steering box in my '67 Panel Truck with the LS1 power steering pump since 2015. I have had no problems with it. I just had to use the adapters in the steering box for the newer hoses: Borgeson 923122GM o ring adapter.
https://www.amazon.com/Borgeson-925122/dp/B01E2Q1NO4
LockDoc
Leon
