12-28-2022, 01:52 AM | #1 |
Glove Box Light Wire Question?
On My 69 C10 Can I Tie The Glove Box Light Wire ( Orange )
To The Same Circuit As The Cigarette Lighter Wire? Posted via Mobile Device |
12-28-2022, 02:18 AM | #2 |
Re: Glove Box Light Wire Question?
Or The Orange Courtesy Light Wire?
12-28-2022, 02:55 AM | #3 |
Either circuit would work as both are always hot, un-switched by ignition.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
01-03-2023, 12:35 AM | #4 |
Can I Hook The Glove Box Light To The Gray Interior Light Circuit?
I Dont Really Care For Power To The Glovebox light if the trucks off Posted via Mobile Device |
01-03-2023, 02:51 AM | #5 |
Interior light circuit is also unswitched by ignition. It will only be switched hot when a door is open or the dome light is turned on at light switch, this circuit is switched to ground. The others mentioned may be as well. Been a while so I would have to check diagram.
Edit- Really need to check diagram. Courtesy/interior lights the same. They are dimmable at light switch. Believe there may be a switched ignition terminal at fuse cluster just use that if you do not want it work with ignition off.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 01-03-2023 at 03:16 AM. |
01-03-2023, 10:52 AM | #6 |
Thank You. Im Just Gonna T-Tap Into The Orange Wire Running To The Courtesy Lights On The Passenger Side
