Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 01-04-2023, 12:31 PM   #1
C130Nav
1971 2wd to 4wd conversion build
Saved a '71 burb from an early death as a "Crew cab" donor body a few years back.
Now, doing a 4wd / LQ9/4L65E conversion. Sourced a 8" lifted '70 4wd 'burb chassis that was modded to fit a LWB truck. Unf*cking it so 'burb body fits back on it was step one, and rebuilding everything.
C130Nav is offline   Reply With Quote
Old 01-04-2023, 12:33 PM   #2
C130Nav
Re: 1971 2wd to 4wd conversion build
Drivers side rocker/floor. Very clean
Old 01-04-2023, 12:38 PM   #3
C130Nav
Roamed the backroads of northern AR
Old 01-04-2023, 12:44 PM   #4
C130Nav
3rd door rocker repair
Old 01-04-2023, 12:46 PM   #5
C130Nav
Passenger door rocker repair
Old 01-04-2023, 06:20 PM   #6
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I will be doing a conversion on a Longhorn. Got all my parts from a 72 Burb 4X4 that is getting beefed up.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 01-04-2023, 06:24 PM   #7
CG
BlahBlahBlah
Keep the pics coming Nav, looking good so far!
Old 01-04-2023, 09:56 PM   #8
C130Nav
Smitty,
The rear body mounts are different in truck VS. 'Burb. I'm looking for 4wd 'burb body mounts for the #4 position(above the front leaf spring mount) forward of the rear axle. Since you won't be using them when mounting the Longhorn bed, I'll buy them from you when you remove them. Let me know
Old 01-04-2023, 10:02 PM   #9
C130Nav
Pass rocker complete; rotted cowl spot repaired. Damn critters...🤣
Old 01-06-2023, 01:49 AM   #10
BAD1916
Glad you saved that. Looks too clean to have been cut up for a crew cab. I like the direction that you are taking this. Will follow along for sure.
BAD1916 is online now   Reply With Quote
Old 01-06-2023, 08:59 AM   #11
Warrens69GMC
Warrens69GMC's Avatar
Good job!
Old 01-08-2023, 04:33 PM   #12
C130Nav
Spent some "nasty time" on my back with a pressure pot sandblaster, doing some underfloor cleanup. Still need to get under there and touch up some areas again this week, but looking pretty clean so far.
Old 01-08-2023, 04:41 PM   #13
C130Nav
More underfloor cleanup; qtr panel rot on pass side behind 3rd door; and pass floorboard all cleaned up.
Old 01-08-2023, 05:29 PM   #14
LockDoc
The Older Generation
LockDoc's Avatar
That thing still looks pretty clean. It would be nice to find one like that around here....
LockDoc
Leon
Old 01-11-2023, 01:56 PM   #15
HO455
HO455's Avatar
Great work! I for one are very glad you saved it.
I'm pretty sure Flynavy30 will be following your progress.
RIP Bob Parks.
HO455 is online now   Reply With Quote
Old 01-13-2023, 07:27 PM   #16
C130Nav
Found a full front sway bar setup off a late 70s square body to install. After sandblasting crossmember and swaybar, got it all mocked up and positioned in place. Had to redrill new holes into the frame for the new crossmember and swaybar mounting brackets. Now to order new bushings all around, and get it all repainted. Will no doubt have to modify the original style front brake lines, due to different mounting angle of new crossmember.
$50 well spent 👍
Old 01-13-2023, 09:09 PM   #17
71meangreenc10
Originally Posted by C130Nav View Post
Smitty,
My bad,
I was saying I was converting a 2wd Longhorn to 4WD with a suspension from a 72 Burb. I'm using the Longhorn frame and it is already leafs in the back. The whole front with mounts came off the Burb.
My buddy is doing a conversion and I will see what brackets he is not using.
Smitty
71 C30 Wrecker
Old 02-07-2023, 10:15 PM   #18
C130Nav
Been a few weeks since last worked on the truck.
Got the section between 3rd door and rear wheel replaced. Just the outer panel was swiss cheesy.
Patch panel fit reasonably well; but lower contour was more curved than original. Had to make some relief cuts to make it match 3rd door rocker contour.
Old 02-07-2023, 10:23 PM   #19
C130Nav
Sandblasted and painted inner quarter area. Relief cuts on front of patch made it line up with rocker nicely. Welded up patch, ground it down flush, ready for a skim coat to blend in the two panels.
Old 02-07-2023, 10:30 PM   #20
C130Nav
Next up is right rear quarter. Lots of little swiss cheese holes to fix; especially around the reverse light area. Good thing the patch panels cover that area. Didnt get the triangular rear inner patches, but will probably have to replace those as well. Wont know til old lower quarter is cut away
Old 02-07-2023, 11:51 PM   #21
LockDoc
LockDoc's Avatar
Lookin' good so far....
LockDoc
Leon
Old 02-09-2023, 08:32 PM   #22
C130Nav
Cut away the bad part of the passenger side rear qtr. Still have to trim patch panel, and cut away bad reverse light area. Then sandblast away the rust, prime and paint inner qtr arwa. Will probably take out spare tire well out afterwards and blast/repaint it.
Old 02-11-2023, 07:06 PM   #23
BAD1916
Nice work
Old 02-25-2023, 07:47 PM   #24
C130Nav
Sandblasting and coating the understructure.
Old 02-25-2023, 07:53 PM   #25
C130Nav
Fitting, cutting and rewelding of patch panel.
PS. It doesnt fit well around the rear area of qtr near the tailight.
