Old 01-14-2022, 12:19 AM   #251
72cs20
Re: Project 1966 K20 adventure rig
I have read that by design the straight cut gears make noise. Some say it isn't bad, some say it is. I'm not done working on making it easier to live with.
As you said, adding more insulating material or maybe a heavier weight oil could help. I like this thing. it's fun to use and I want to find a happy medium.
And by the way, Advanced Adapters told me over the phone that the reason they discontinued it was because of the noise complaints.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827
62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583
72cs20 is offline   Reply With Quote
Old 01-15-2022, 02:45 AM   #252
350TacoZilla
Oh yeah straight cut gears whine for sure. Muncie M20 & M21 are way quieter in car than M22 for that reason though straight cut gears are also stronger if all other things are equal.
I meant mechanical fault more like its not eating a bearing or something, the turn the radio up more till the problem goes away solution that ends up costing you 10x more to fix later.
350TacoZilla is offline   Reply With Quote
Old 04-04-2022, 12:15 AM   #253
72cs20
There is now a bit over 1100 miles on the odometer and the testing phase is going well. In order to flesh any issues I drive the truck whenever possible and so far only the rear driveshaft has needed immediate attention. A vibration between 50 and 60 mph. It took a few tries but the driveshaft shop finally got it balanced properly.
On the to-do-list was to fix the overdrive unit leak. I decided to take the whole trans and t-case as one unit and back it out far enough to apply the necessary amount of sealant. A solid quarter inch bead around the tranny front bearing retainer and shove it back into the back of the od unit and it's good! No more drips. Unfortunately I got so busy with this I didn't take any pics.
Fixing the od leak required removing the seats and flooring. A good time to install the rear of cab covering before the seats go back in.
And after the flooring went back down, install the permanent shifter boots.
The front axle needed a new pinion seal. I removed the yoke only to find it in bad shape. Ordered a new one. The pinion shaft itself has a lot of play in it so it looks like the front diff will need some attention.
Old 12-29-2022, 12:59 AM   #254
GottaK20
Hey man, this is one of my favorite builds on here, any updates?
GottaK20 is offline   Reply With Quote
Old 12-31-2022, 09:47 PM   #255
72cs20
Wow! Time has flown by this year. Thanks for the reminder. Work on the truck continues. I'll get an update posted this week.
Old 01-05-2023, 12:45 AM   #256
72cs20
It has been about 8 months since the last update on this build. There are now 4200 miles on the clock and the drive train is performing well. Steering, braking and overall handling are good for this type of vehicle. But, respect must still be shown to curves in the road.
The electrical system, lights, and wipers are working flawlessly.
The winch got 150 ft of new 5/16 cable with new hook.
I had a new windshield and gasket installed. Much better fitment now.
Of course, nothing is perfect and there have been a few annoyances. I had to replace the radiator and fan clutch again. The Vintage Air system has a leak. It won't hold refrigerant for more than a week.
With all the rain we're getting, I've got water coming in from under the dash at each end next to the doors. I don't think it is coming from the windshield.
On the restoration side, I went through both doors with all new latches, relays, window regulators, door checks and window scrubbers and felts. They got new paint too.
I'll get pics up asap. Having trouble posting them right now.
Old 02-11-2024, 11:37 AM   #257
72cs20
I think my posting issues have resolved. My apologies to anyone still interested in this thread.
I finally decided to settle on a tire and wheel combo for the dirt. Dorman 16x7 steel wheels with 255/85-16 Falken Wildpeak M/T's.
Before -
Name:  K20 aluminum wheels 2.jpg
After -
Name:  K20 steel wheels 2.jpg
Name:  K20 steel wheels 1.jpg
Much better!
Old 02-11-2024, 12:46 PM   #258
mattbert56
mattbert56's Avatar
Lookin slick man. I've been on and off this forum for years after finishing my 65 k20. So cool seeing folks still building old iron. I fit up a slid in pop up camper in my k20 this summer. Neat seeing others like that look too. 👌
Well that didn't go as planned.
1965 k20 buikd thread: http://67-72chevytrucks.com/vboard/s...=628346&page=6
mattbert56 is offline   Reply With Quote
Old 02-11-2024, 01:39 PM   #259
72cs20
Thanks! I've been through your thread. Nice work. That camper is a good fit for these trucks.
Old 02-11-2024, 06:04 PM   #260
cwcarpenter98
cwcarpenter98's Avatar
Welcome back! I like the new wheel and tire setup. It fits the look of the truck much better in my opinion
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 02-11-2024, 06:39 PM   #261
72cs20
Thank you! And I concur!
Old 02-12-2024, 02:19 AM   #262
straight6chevyguy
straight6chevyguy's Avatar
Looking good!
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 chevy c20 350 4speed
1998 chevy c1500 4.3L 5speed
2002 Chevy s10 4.3L auto 4x4
Plus a Mercury & some Fords... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 02-12-2024, 07:19 AM   #263
joesscamaro
Great choice on the tires & wheels!
joesscamaro is offline   Reply With Quote
Old 02-16-2024, 09:00 PM   #264
72cs20
Thank you fella's.
Old 02-18-2024, 10:42 AM   #265
350TacoZilla
Definitely suits the truck! I like the old 9.00-16 tires but those are near hens teeth now so I have also started using 255\85R16 or 255\80R17's when I can find them. Currently both my wifes 1500 ram and my dad's ram 2500 are running the 255\80R17 mastercraft CXT's and they have been a good tire for us but kinda ridiculous that they cost more than a larger tire of same brand\model.
I really wish there was a redneck millionaire out there that would invest in a company to start remaking the old size's and tread patterns again, maybe even be a decent person that doesn't price gouge lol you know while I'm dreaming.
