Old 11-25-2022, 10:28 AM   #76
G&R's57GMC
G&R's57GMC's Avatar
Re: My new Beater 1959 GMC
That s-10 axle is too narrow for your truck . It will require tubs and reverse rims along with relocation of the springs .
A nova rear axle would work without much work .
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 11-26-2022, 01:50 PM   #77
joedoh
joedoh's Avatar
love the transformation! i prefer the 55-7 front end too!
Old 11-29-2022, 02:18 PM   #78
hardwaa
hardwaa's Avatar
Progress.
hardwaa is offline   Reply With Quote
Old 11-29-2022, 02:26 PM   #79
hardwaa
hardwaa's Avatar
Rear axle is a 3:42 rear ratio out of a 6 cyl s-10.
I LOVE BURNOUTS:metal
NO BOZO's
Old 11-29-2022, 02:28 PM   #80
hardwaa
hardwaa's Avatar
Front end progress on the 59. These era trucks are real neat to play with, very simple how they all bolt together. 👍🏻👍🏻
NO BOZO's
Old 12-04-2022, 11:21 PM   #81
hardwaa
hardwaa's Avatar
Out of the box mustang 2 mock up dropped spindles and 5/8 narrowed A arms.
Old 12-04-2022, 11:23 PM   #82
hardwaa
hardwaa's Avatar
Tweaking it some, 2” additional lower and an additional 1/2 “ pushed front wheels forward…Me Likey!!!!!!!!! Time to make it permanent.
Old 12-05-2022, 12:34 AM   #83
dsraven
Nicely centered wheel. Check all the angles, tack, recheck before welding in. Digital level is really handy.
Antidive angle on top control arm pivot
Lower control arm angles from front and side at ride height. What I do is extend the pivot shaft out through the front and place long level or straight edge between them, then digital torpedo level on top of that to ensure side to side on crossmember is level. Then torpedo level on one shaft at a time to get the fore to aft level. Then level the lower cross member side to side. Then check the upper control arm for side to side angle.a slight angle down to frame may be ok, up to you.it affects tire lean as suspension cycles. So tire doesnt hit fender.
Anyway, it looks like you researched before starting. Keep posting up pics as you go. Maybe get some of us slackers off the couch.
dsraven is online now   Reply With Quote
Old 12-13-2022, 09:01 AM   #84
6DoF
6DoF's Avatar
stretched ftw
6DoF is offline   Reply With Quote
Old 12-13-2022, 01:33 PM   #85
57tailgater
Those front engine mounts resemble what I had done in m '57 years ago.
57tailgater is offline   Reply With Quote
Old 12-13-2022, 08:23 PM   #86
dsraven
what will the clearance be at the front of the rockers? hard to tell from the pics, but curious what rake angle you chose.
Old 12-24-2022, 06:59 PM   #87
hardwaa
hardwaa's Avatar
Old 12-25-2022, 10:21 PM   #88
dsraven
last post was a blank screen.
Old 12-26-2022, 03:36 AM   #89
hardwaa
hardwaa's Avatar
Progress pics. Mock up motor and trans in finalizing location.
Old 12-26-2022, 03:44 AM   #90
hardwaa
hardwaa's Avatar
Can’t wait to do burnouts.
Old 01-04-2023, 12:39 PM   #91
6DoF
6DoF's Avatar
and we can't wait to see the vids!
Old 01-05-2023, 10:28 PM   #92
hardwaa
hardwaa's Avatar
Stock steering column mod. I like to run the stock steering wheel.
Wheel barrow bearing and shaft collar cost me $7.41 at the hardware store. Simple easy fix. Will shape end of steering shaft for Double D coupler.
Old 01-06-2023, 03:25 PM   #93
57tailgater
It will be interesting to see how your headers fit with the IFS and tires/wheels. What kind are they? Don't think I have seen ones with that big of a bend radius in them. I like the concept if it will work!
Old 01-06-2023, 04:42 PM   #94
daveshilling
daveshilling's Avatar
Nice, that's a $40 problem usually.. who knew?!
daveshilling is offline   Reply With Quote
Old 01-07-2023, 06:31 AM   #95
hardwaa
hardwaa's Avatar
No idea on brand. They were a swapmeet special. I have always wanted to run fenderwell headers. We will see how they fit with all the rest of the components up front.
Old 01-29-2023, 07:23 AM   #96
hardwaa
hardwaa's Avatar
Progress. Just having FUN!
Old 01-29-2023, 11:22 PM   #97
57tailgater
Oh my love the white headers!! What did you paint them with?
Old 01-30-2023, 03:44 AM   #98
hardwaa
hardwaa's Avatar
More FUN! Alignment is of but you get the idea.
Old 01-30-2023, 01:43 PM   #99
lolife99
67-72 parts collector,…
lolife99's Avatar
Love it.
You got that front wheel in the perfect position.
I see that done wrong SO MANY times.
Engine and wheel/tire choice is spot on.
Keith
Convert to disc brakes.
Old 02-01-2023, 10:33 AM   #100
dsraven
curious to see how the steering shaft fits through the header tunnel.
engine and headers look awesome. where will the exhaust dump out when you're all done?
