Old 01-06-2023, 06:03 PM   #4
LS short box
Re: Drip rails
On my 68 it had a couple bad spots in the vertical part of the drip rails. I cut out the bad vertical spots. Then I got some 1/8"? flat stock from the hardware. Cut it to length and welded it into place. I had to grind the top of the flat stock to match the stock drip rail height. Once done you could not tell.
