Old 01-12-2023, 11:50 PM   #7
KyleSeal
KyleSeal's Avatar
Re: Seasoned Patina Guys: what do I do?
Originally Posted by davischevy View Post
I have been using Loctite extend for 30 years to seal rust. If you use serrated washers on grounds, you shouldn't have a problem.
Before you clear the top of the dash, try using the Extend. It leaves a finish that doesn't look "fake". Just scuff with a pad, wipe it down and spray it on.
I ended up going with this on the inside of the dash. I tested it out on an old roof skin I had that had the same level of rust, and I like the outcome. Not waxy or wet, dried well. I will still clear the exposed side of the dash, as it will match my interior that is worn and will be satin cleared. But I think this Loctite stuff works pretty well.
C10 Club Virginia President
Toano VA
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
dash, paint, patina
