Old 08-02-2004, 11:20 AM   #1
Greg Carter
Heater Blower motor always on
Hi,
I recently purchased a 1982 GMC 7000 (5 ton dump and 4ton HIAB crane). The interior is pretty much the same as a regular GMC pickup. The blower motor connector was disconnected, after I hooked it back up I found out why It is always on (with ignition on). Even with the fan setting at "low" and the temp slider to off. Any ideas?
thanks.
greg
Greg Carter is offline   Reply With Quote
Old 08-02-2004, 11:36 AM   #2
Jonboy
Slots go on anything!
the fan switch on the dash may be shorted out. Try unplugging it with the blower connected and see if it stops.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 08-02-2004, 02:13 PM   #3
76bonanza
76bonanza's Avatar
That is the way they all are it always runs most people unplug it in summer. I ran a toggle switch to mine so I can switch it off and on. As far as I Know all the chevys are that way at least all the ones I have ever seen.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 08-02-2004, 02:33 PM   #4
ocbaud
Garage Queen Material
its to help keep fresh air circulated since these trucks have such "great" cab sealing.
they thought we would suffocate without air coming in hahahah
ocbaud is offline   Reply With Quote
Old 08-02-2004, 04:16 PM   #5
BillyJack
Could you give some instructions on wiring that toggle switch? I noticed mine did that and thought it was messed up. I was gonna start a thread but was too lazy.
I'd like to shut that sucker off. It's annoying to turn the key and hear it (mine needs replacement i think cause it sounds pretty worn out.)
BillyJack is offline   Reply With Quote
Old 08-02-2004, 06:11 PM   #6
76bonanza
76bonanza's Avatar
The wire the you pull out from the motor in the engine compartment I just cut it and ran a switch into the cab.
1968 c10
lowered 3" 4"
Old 08-02-2004, 07:43 PM   #7
78SilveradoSWB
78SilveradoSWB's Avatar
Eric is correct on this one GM though design this in on purpose, so there is always fresh air circulating in the cab for our pleasure.
Mitch
1978 Chevrolet Silverado C 10
454 BB, TH400
78SilveradoSWB is offline   Reply With Quote
Old 08-02-2004, 08:03 PM   #8
screwballl
Tonawanda 454
screwballl's Avatar
i seem to have the problem of it NEVER coming on, even with a new blower motor... no matter where the switches are set to its never on.. it used to work (but only through the floor vents, it never moved from there).
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 08-02-2004, 08:11 PM   #9
ocbaud
whats up with the laugh????
you think i'm a tard or something???
Old 08-02-2004, 09:31 PM   #10
swervin ervin
You get what you pay for
swervin ervin's Avatar
I think he's saying you are wrong most of the time. As for the tard part, everyone knows this. :p
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 08-03-2004, 02:24 AM   #11
apstguy
LED King
apstguy's Avatar
My blower motor isn't always on. Am I missing something here? GM did make a "flow through" cab - if you are moving, air is pushed through the front cowl through the floor vent to the vents in the bottoms of the doors. That is why there are vents in the bottom of the doors.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 08-03-2004, 03:01 AM   #12
78SilveradoSWB
No implications whatsoever...
Mitch
454 BB, TH400
Old 08-03-2004, 05:08 AM   #13
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
My truck blower turns off If I turn it off. Had a 78 Coupe Deville that always ran if the key was on.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 08-03-2004, 05:23 AM   #14
jimfulco
I think the A/C-equipped GM vehicles had them run all the time so the A/C wouldn't ice up. Or maybe so they would wear out faster & they could sell you a new one.
jimfulco is offline   Reply With Quote
Old 08-03-2004, 02:38 PM   #15
76sierraclassic
Mine's always on in my '76. It used to blow out the regular vents until I changed out my heater core, and now it blows out the floor vents. I don't know what I changed, but it must have been something.
Mike
76sierraclassic is offline   Reply With Quote
Old 08-04-2004, 02:16 PM   #16
Greg Carter
Thanks for the replys. Sounds like it may function that way.
Old 08-04-2004, 05:03 PM   #17
Zilverado
Zilverado's Avatar
My '77 (non-A/C) was an "always on" set-up. My '86, A/C truck actually turns off.
Funny, I'm not suffocating
Zilverado is offline   Reply With Quote
Old 08-05-2004, 11:06 AM   #18
KShortell
KShortell's Avatar
Yup, my '86 is the same way. The blower is off when the switch is off. Both the motor and the switch/control assembly have been replaced over the last 6 years. It's always been like this. Now, you do get some flow-through ventilation at speed, but not from the blower motor.
Semper Paratus
KShortell is offline   Reply With Quote
Old 08-05-2004, 01:39 PM   #19
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
The fan switch is set to be "always on" for the non-A/C trucks. A/C trucks you can turn the fan off.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 08-09-2004, 02:47 AM   #20
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
Angry
The fan is always on on my 76 with factory A/C. Rather annoying to say the least. I even replaced the relays. Off means off!
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 08-09-2004, 03:03 AM   #21
Russell
Professional Grade
Russell's Avatar
I haven't had my heater fan hooked up for a long time now, but my heater and defroster still work just fine. Just takes a bit longer, hehe
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
