Old 01-10-2023, 04:59 PM   #3526
Johnl48
Re: What did you do to your truck today.The 3rd chapter
Got my hood on finally
Old 01-10-2023, 06:21 PM   #3527
Trio
Trio's Avatar
sanded and spray painted the spare wheel, before getting a pizza cutter installed on it this weekend.
Trio
1971 C20 350/700R4
Trio is offline   Reply With Quote
Old 01-11-2023, 09:06 PM   #3528
Grumpy old man
Grumpy old man's Avatar
I had a new driveshaft made for the 67 . 083 tube x 3.5" spicer joints . One more bite off the elephant .
Old 01-11-2023, 10:47 PM   #3529
Steeveedee
Who Changed This?
Steeveedee's Avatar
Changed the oil. I don't remember the last time I did that, but after coming back from our rental house with the oil nice and hot, I finally did it. I don't normally take the truck over there, but I had to have a nice long straightedge to guide the circular saw to trim down a gate. I build things to tight tolerances, and when I built that gate 8 years ago, it was dry and summer. With all this rain, the wood swelled up and the gate was hard to open and close. I'm sure that it has been this way in the past with rain, but the renters never complained. If they had said something, I'd've been all over it. My best complaint about them (after 9 months of not paying rent!)- we had a new toilet put in the rental house, and for whatever reason, the plumber only turned the house water supply valve on part way. Two weeks after that, they were complaining about low water flow. While I will say that the plumber should have opened the valve all the way, they should not have waited two weeks to say something. When I went over to look at the problem, and found it, one of the renters said, "****", because he knew that even he should have seen such a simple problem, having worked for a plumbing company in the past.
~Steven
Simi Valley, CA
Old 01-15-2023, 02:15 PM   #3530
Johnl48
Got my door panels painted and put on
Old 01-15-2023, 02:53 PM   #3531
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looks good
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 01-15-2023, 03:33 PM   #3532
Steeveedee
Who Changed This?
Steeveedee's Avatar
Nice! Brought the color right through the door skin!
~Steven
Simi Valley, CA
Old 01-15-2023, 11:16 PM   #3533
'68OrangeSunshine
'68OrangeSunshine's Avatar
Nice.
Old 01-16-2023, 02:39 AM   #3534
lok-dawg
lok-dawg's Avatar
Put a trickle charger on the battery... does that count for anything?
'72 Chevrolet C10- Deluxe/5.7/Short Fleetside
'02 Chevrolet Tahoe- LT/5.3/4x4
'13 Ford F150- XLT/5.0/SuperCrew/4X4
'14 Subaru Impreza- Limited/2.0/Sedan/AWD
lok-dawg is offline   Reply With Quote
Old 01-16-2023, 09:37 PM   #3535
towbar
towbar's Avatar
Location: Marshall, NC....heart of the Appalachians.....aka, Gods country!!
I did a rear frame C notch, 4 shocks, greased the front suspension, tracked down a trans leak on my 84 squarebody....all in preparation for the hot rod power tour this year.
towbar is offline   Reply With Quote
Old 01-17-2023, 04:51 PM   #3536
72c20customcamper
72c20customcamper's Avatar
Started on my 68 a seat . Ran into a snag the original foam is most likely compressed and the skin is fitting loosely. So I’m going to add some filler to it either poly fit wrap or put jute backing behind the foam . Guess I’ll have a delux or CST seat in a plain Jane .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 01-17-2023, 04:56 PM   #3537
72c20customcamper
Ohh and I had redo a bed board . I moved some stuff and can of paint fell on it putting a big dent in it . I can assure you that I did my best Samual L Jackson “ The hit man’s bodyguard “ imitation .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 01-17-2023, 05:32 PM   #3538
Johnl48
Blasted and painted my seat frame
Old 01-17-2023, 08:22 PM   #3539
jaros44sr
jaros44sr's Avatar
I've heard that if you put a damp cloth on top and use your wife's iron it will pull the grain up
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is online now   Reply With Quote
Old 01-18-2023, 12:07 PM   #3540
72c20customcamper
I fixed it by sanding the finish off and lightly wetting it with distilled water. Which popped the grain I let it dry completely sanded then resealed with 5 coats in the repair area and one coat over the entire board .
Repair , it slightly altered the grain but you need to look real close
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 01-18-2023, 03:12 PM   #3541
72c20customcamper
Not at all too happy with the seat skin . PUI brand I added the fiber mat which helped with the top and sides fitting tight overall the seat skin is tight ,but no matter how much I stretch the vinyl and heat the puckers won’t come out . If I pull too hard the piping gets distorted around the perimeter . I’m thinking the one side isn’t stitched correctly . Had the same problem with a PUI headliner in my Chevelle . They puckered it at the seam while sowing it .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 01-18-2023, 05:15 PM   #3542
72c20customcamper
Made a new spring from a mattress box spring . Seems to work well
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 01-18-2023, 06:42 PM   #3543
72c20customcamper
Don’t believe this skin is for a 68 full foam even though the box and paperwork say it is . I had to modify it to fit the seat frame . The seat bottom is suppose to clip all around the perimeter was about an inch to long . I had to put a wire in the felt and hog ring it . I got the pleats to line up on one side and the other side is off by about 1/4 of an inch no excuse for that . But it’s together not perfect but it’ll have to do .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 01-20-2023, 08:12 PM   #3544
Cement was too cool to lay on, so did some cruising around the area.
Palf70Step is online now   Reply With Quote
Old 01-20-2023, 08:30 PM   #3545
Steeveedee
Who Changed This?
Steeveedee's Avatar
^ When was Jefferson Davis president?
~Steven
Simi Valley, CA
Old 01-20-2023, 11:26 PM   #3546
Civil War, He was the president of the Southern folks.
Old 01-22-2023, 05:21 PM   #3547
72c20customcamper
Did the seat tracks today it’s a pleasure working on parts that aren’t covered in rust .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 01-22-2023, 05:26 PM   #3548
72c20customcamper
And somewhere during the process I lost the little clip that holds the spring and wire linkage . So I made a new one out of a left over piece of tool steel from knife making. Lots of hand filing as I didn’t want to overcut it on my belt grinder . Not my favorite thing to do in 90+ degrees . Turned out pretty well
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 01-22-2023, 05:29 PM   #3549
3757chevy
3757chevy's Avatar
Turned out real well , nice job.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 01-22-2023, 07:01 PM   #3550
Sheepdip
Sheepdip's Avatar
The one and only Confederate President I might add 1861-1865
He also served as a United States Senator for Mississippi and also in the House of Representatives prior to the Civil War.
Sheepdip is offline   Reply With Quote
