Old 11-06-2022, 03:14 PM   #151
squarebodyaddict
Re: 1973-1991 Dual fuel tank systems theory of operation
Originally Posted by hatzie View Post
The fuel pump relay may not be passing full voltage through the relay switch contacts anymore. They can get dirty just like ignition breaker points.
Back probe relay Terminal A and Terminal E to a good ground.
Terminal A is the input voltage from the ECM.
Terminal E is the output voltage to the tank switch and selected fuel pump.
Thanks for the Info Hatzie.
I tried 4 used relays and 1 brand new relay, all had same result... 12.4V back probing Terminal A and 8.9-9.1V on Terminal E, grounded direct to battery.
I'm not great at finding info in these forums, I feel like I've searched every possible combination of word search... would like to know any suggestions for a next step.
P.S. Some Clarification:
91 V3500 454: While testing the A terminal (key on) 12.3+/- volts. Testing the E terminal I get 12.3V+/- at initial key on and while cranking, but falls back to 9Volts +/- when not cranking/not triggering fuel pump....
Interestingly enough I did the same test on my 91 V2500 Suburban 350 it gives similar readings except when testing E terminal key on when not cranking/not triggering fuel pump it then gives a 9 MILI VOLT reading.
Any Idea why the V3500 gives 9Volt reading while the same test on the V2500 gives different reading of 9 Mili Volt???
Also I checked firewall and Engine Ground both seem perfect.
Last edited by squarebodyaddict; 11-06-2022 at 06:48 PM. Reason: More/New Information
squarebodyaddict is offline   Reply With Quote
Old 11-06-2022, 06:29 PM   #152
hatzie
Moderator
hatzie's Avatar
Either the relay is not passing volts through the switch contacts or the terminal in the E position of the plug is corroded or loose or both.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 12-19-2022, 12:18 PM   #153
rodstored-72
chevy truck fan
rodstored-72's Avatar
not sure if my question is good for in here... but here it is... I am looking for info on how the tank vents were/are setup on dual tanks related to the venting lines & the charcoal canister? i am guessing there is a "diagram" somewhere or a hose routing for this?
thank you for any info provided....
Hatzie, i have mentioned it before, but feel it needs to be mentioned again that your time & effort on this thread is VERY appreciated
rodstored-72 is offline   Reply With Quote
Old 12-21-2022, 09:38 PM   #154
hatzie
Moderator
hatzie's Avatar
There are three crossover lines from the LH tank to the RH frame rail. Supply, Return, and Vent.
On my 76 I ran a single vent line from the stock vapor can location under the LH battery across the cross-member under the radiator and up the RH frame rail to a Tee. The stock vapor line should be the same for the single and dual tanks.
Old 01-21-2023, 09:31 PM   #155
bigdaddy4x4
bigdaddy4x4's Avatar
i have 77 gmc crewcab with dual tanks did a ls swap and used the 87 efi tanks with 96 vortec fuel pumps and pollack switch over valve my ? is does the dual tank small fuel gauge i got to replace the orginial oem gas gauge need to be wired different for the small fuel gauge to work like it should ?
bigdaddy4x4 is offline   Reply With Quote
Old 01-21-2023, 10:23 PM   #156
SunSoaked
SunSoaked's Avatar
Depends what the instructions say.
SunSoaked is offline   Reply With Quote
Old 01-21-2023, 11:51 PM   #157
bigdaddy4x4
dont got no destructions
Old 07-23-2023, 01:53 PM   #158
cdub2010
My 1991 R3500 truck stopped running, no fuel to injectors, since I know the right side pump was dead, I dropped the drivers tank and found the ground was pinched and destroyed, the tank was leaking and sender was doused in tar. Best to replace and start new. I had found a broken switching valve so that was replaced as well. Connected everything it still wouldnt start.
Checked with a test light no voltage at the drivers pump connection. I have voltage at the nl2 connection, and I have traced voltage to the pass. side pump connection, but pass. side shows voltage in both right and left switched positions.
my wires on the dash switch are all white and 1 black, this truck has been a disaster when it comes to wiring, total clown show.
What to look for? ground problem? wire burnt or rubbed thru?
cdub2010 is online now   Reply With Quote
Old 07-24-2023, 04:13 PM   #159
MiniD
How are you measuring voltage for the fuel pump?
Does your fuel gage work?
1970 C20 SWB convert - 4.8l/4l60e
1985 C10 SWB
MiniD is offline   Reply With Quote
Old 07-24-2023, 05:00 PM   #160
MiniD
BTW... this is the schematic that helped me the most:
1985 C10 SWB
Old 07-24-2023, 10:28 PM   #161
cdub2010
My fuel gauge was inconsistent. I was using a simple test light.
Fixed the issue today. The problem was the ground wire on the tank selector switch. Found it was hacked up and just twisted together. Had to remove the dash to get a good look at it and fix it properly. Truck fired right up.
Old 07-28-2023, 12:44 AM   #162
PowerdbyChevy79
PowerdbyChevy79's Avatar
Some good info here...subscribed!
1966 C10 "Mary"
1967 C10 Custom "Ole Blue"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 08-08-2023, 01:31 PM   #163
rodstored-72
chevy truck fan
I think this is relevent to the thread... here it goes.... is there a particular "proceedure" when utilizing (switching tanks)? does truck need to be running? can you switch "on the fly" while driving? does the proceedure differ if the setup is carbed/fuel injection(swapped to LS engines)?
thanks!
Old 08-08-2023, 01:32 PM   #164
rodstored-72
chevy truck fan
agree.. lotsa good info thanks hatzie for your sharing of the knowledge.
Old 08-08-2023, 06:47 PM   #165
hatzie
Moderator
hatzie's Avatar
You should be able to switch it on the fly even with the diesel engines.
Old 10-17-2023, 10:37 PM   #166
rodstored-72
chevy truck fan
ok, another question.... how does the tank selector valve work specifically related to the power to it and how does it move to open/close either tank when switched at the dash switch? what turns switch "off" when needed after tank selected. finally how can "a guy" check/verify the selector valve is "switching fully" when activated by the dash switch??
thanks!!
Old 10-18-2023, 12:51 AM   #167
MiniD
thanks!!
It is a simple solenoid that is not spring driven. It is moved by reversing the polarity of the 12v and ground to the tan and brown wires. This is done at the selector switch in the dash. It slides a manifold back and forth that lines up ports to route the fuel delivery<and return if EFI>.
The there is a switch that is also activated, though I'm not sure how it works in relation to the movement of the solenoid. That switch directs what sending unit is supply a ground to your 12v from the pink fuel gage line.
If you're looking for more information on the valve itself, I'd suggest youtube and visual explanations.
1985 C10 SWB
Old 10-20-2023, 10:32 AM   #168
hatzie
Moderator
hatzie's Avatar
You obviously didn't read the original sections on how these valves work.
This is a cutaway view of the valve in question.
It is NOT A SOLENOID valve.
Old 10-20-2023, 02:03 PM   #169
rodstored-72
chevy truck fan
hatzie, thank you for the reply, so do the contacts start/stop power to the motor and how can "a guy" check to verify the motor switched completely from one side to the other (not partially switched or in between the ports)?
the system in question is a LS swapped '86 c10 with '87 tanks, '87 sending units & EP381 F.P.s. the 12v signal is coming from the signal at the stock '13 ECM and harness.by chance does the motor require a timed amount of power to move completely? my F.P is low (50-55psi) and trying to verify the valve is not causing the lack of fuel.... ??
again appreciate your time and knowledge.. you are always very helpful on the board.
Old 10-21-2023, 06:30 PM   #170
hatzie
Moderator
hatzie's Avatar
The valve motor shuts off when it reaches the end of travel.
The in-tank fuel pump runs from the valve motor wiring in stock dress.
Notice the diodes inline with the motor.
Old 10-21-2023, 08:41 PM   #171
MiniD
OK... a motor instead of a solenoid. That doesn't really matter in this context. It's a polarity reversal moving a plunger back and forth.
1985 C10 SWB
Old 10-21-2023, 08:48 PM   #172
MiniD
Don't use the standard tank selector valve with an LS setup. The selector valves are only rated up to 65 psi. You can use it for the return but the supply needs a different solution. I went with a straight T fitting from the tanks (each tank feed needs a check valve prior to the T).
The tank selector switch (EFI - which locks in position) will also toggle the power to your fuel pumps or fuel pump relays. This can decide which tank to pump from. You can still have the stock switching valve work for the return line routing (much lower pressure) and that way original wiring still works for the fuel guage.
<edit>since you said "FPs", I assumed you are referring to in tank fuel pumps. You can use the stock fuel tank switch if you're using a fuel pump up-stream</edit>
1985 C10 SWB
Old 04-22-2024, 08:14 AM   #173
Dleslie212
Is itnpossible to wire these in such a way that return goes to the incorrect tank? I've verified my return lines aren't crossed, but when I fill both tanks, the tank that I DONT currently have selected starts spewing fuel from the fill port. I just completely rewired the truck, so wiring is the only thing I can think of
Dleslie212 is offline   Reply With Quote
Old 04-22-2024, 08:28 AM   #174
MiniD
It is not possible to wire it so the returns go to the "wrong" tank. The tank switch switches both the supply and return with the same signal. It is possible to wire it so that the wrong tank is selected but the supply should be coupled to the return.
Of course, there are ways to screw that up but they involve re-plumbing your fuel lines. Just re-wiring can't do that.
1985 C10 SWB
Old 04-22-2024, 08:43 AM   #175
Dleslie212
That's what I was thinking. I can easily just cross the return lines, but it bugs me not knowing why that's happening
