Old 01-24-2023, 09:22 PM   #1
Furno68C20
292 exhaust manifolds
I’m currently swapping a 292 in place of a 250. 68 Truck originally had a 250. The 292 I have has a 3” 3 bolt triangular exhaust manifold flange. This causing a problem since the truck has a 2” 2 bolt flange.
From the research I’ve done I should be able to use a 250 exhaust man that will fit a 292 head and then mate to the OEM exhaust.
Did the 292 come with different exhaust manifolds based on what size the truck was? C10/2030 - 2” manifolds: c50/60 3” manifolds?
Furno68C20 is offline   Reply With Quote
Old 01-24-2023, 10:43 PM   #2
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
Re: 292 exhaust manifolds
Be aware that you are probably going to have to redo the head pipe anyway. Since the 292 block is 1 3/4 inches taller the exhaust is going to hit the frame crossmember before the flange comes up high enough to bolt up. That's what happened on my swap.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 01-24-2023, 11:52 PM   #3
Wrenchbender Ret
You are exactly right. The larger manifold came on the larger trucks. 1 1/2 tons & up. The 250 manifold will fit the 292 engine but the larger manifold is better. The small manifold is restrictive on a 292 engine. It causes warpage & cracks in the smaller manifolds.
You will need to fab a exhaust pipe extension or have a muffler shop make it up.
George
Wrenchbender Ret is offline   Reply With Quote
Old 01-25-2023, 09:40 PM   #4
Furno68C20
You will need to fab an exhaust pipe extension or have a muffler shop make it up.
There’s always some modification to do. There is a break in the exhaust pipe under the driver door. I’ll bring that piece along with the manifold to have fab up.
Thanks for the info here.
George
Old 01-26-2023, 12:29 AM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
I have been running Clifford headers since 1978 on my '68C/10 Stepside, but my Calif-stock 292 was originally equipped with the same exhaust package as a 250, Plus A.I.R.
Old 01-26-2023, 10:34 AM   #6
My opinion is go with 12bolt.com manifolds. Best exhaust setup I feel for any Chevy inline six.
https://www.12bolt.com/store/p153/Ex...0-250-292.html
