Old 01-29-2023, 08:36 AM   #1
K10-Kansas
K10-Kansas's Avatar
Please help identify sender connection
Hi all. My chassis is supposedly a 77 or 78. My 4x4 shifter connects to this part under the truck and ther are 2 blade connectors on it. Maybe for a display that indicates if the truck is in 4x4 low, high, or 2wd mode?
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James
K10-Kansas is offline   Reply With Quote
Old 01-29-2023, 02:45 PM   #2
Dead Parrot
Re: Please help identify sender connection
Is there a 4WD light in your instrument cluster? If it doesn't light, the missing connector could be why.
Dead Parrot is offline   Reply With Quote
Old 01-29-2023, 03:34 PM   #3
kwmech
That's exactly what it does ---indicates when in 4wd
Old 01-29-2023, 11:26 PM   #4
K10-Kansas
K10-Kansas's Avatar
Ok thanks. My cab is a 71. The wiring was half torn apart with lots of missing parts when I bought the truck. I took out 100% of the wiring and am almost done installing the new wiring harness. I don't yet have a dash gauge cluster put in. Where would this light have been in a stock setup? I haven't seen a wire in the new harness for it.
Old 01-30-2023, 12:06 AM   #5
Pontiac1976
Pontiac1976's Avatar
Are you using the cluster out of a77- up truck? Because 72-67 do not have that option as far as I know.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 01-30-2023, 01:13 AM   #6
Dead Parrot
The location varies. I have an 84 CUCV (K30) that has the idiot light cluster. The 4WD light is one of the locations were gauges would go for a gauge setup. I have a cluster out of a square suburban that had gauges and the 4WD light was one of the smaller lights at the bottom of the cluster.
If you wind up with a non-4WD cluster, you could just add a light somewhere fed off that sender. IIRC - both of my 4WD lights were a variation on yellow.
Old 01-30-2023, 01:05 PM   #7
kwmech
I think you would need the cluster that came with the truck that originally came with the 203 transfer case. Never seen a switch on a 205 shifter. That is unless there is a knock out in all the printed circuits for this option
Old 01-30-2023, 04:24 PM   #8
MJN
MJN's Avatar
Not a stock setup in a '72 or older and is not needed unless you need a dash indicator to show you have 4 wheel drive engaged. This is also on a NP203 transfer case which was not available on 73 or older trucks. The 4 wheel lock indicator switch showed up starting in '77.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 01-31-2023, 12:47 PM   #9
kwmech
The 203 transfer case made its debut IN 1973 and was in GM 1/2 and 3/4 tons trucks until 1979. Mostly behind automatics. The majority of the manual transmissions got the 205. But as always there were lots of variations
Old 01-31-2023, 01:03 PM   #10
MJN
MJN's Avatar
According to the GM vehicle info kits only the NP205 was available in 1973 making 1974 the first year for the NP203.
'17 GMC Yukon XL
VCCA member #58596
Old 01-31-2023, 06:06 PM   #11
1976gmc20
My 73 a/t was the 205. I was told that some of the later production for 73 MY was 203. I had a heck of a time getting the correct front driveshaft for it as by that time (79?) all the parts stores said 350/auto was 203. After several tries the one that fit was supposed to be for a six cylinder manual.
Neither my 73 nor my 80 (350/465/205) had a 4wd indicator light that I remember. Back then people could figure out whether they were in 4wd or not, I guess
I bought both of those pickups brand new, which were the only brand new vehicles I have ever owned.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
