Old 02-02-2023, 03:34 PM   #14
Chaparralman1974
Chaparralman1974's Avatar
Re: Dana 44 Ring Gear Swap Question
Originally Posted by jeffahart View Post
I think it would be close. But why not wait till you get the transfer case mounted and the front end sitting on tires and rear springs in. Then you will be able to dial it in. But my guess is the original location will be close but you will have to shim in either direction.
j
I actually decided to just stay with the HO52. It was working, and the only real reason I was thinking of going to the 14 bolt was to have 4.11's front and rear, but the 4.56's will be fine for me. This is just going to be a cruiser to go and get ice cream from time to time and not a daily driver. Also, it will set me in a good place if I do ever decide to lift it and go with bigger tires.
I actually found a couple of 1971/72 Eaton HO52/72 hubs that accept 9/16" studs, so I think that I am going to do the 14 bolt brake mod to the HO52 so that I have larger and more modern brakes. That really gets me the both of best worlds. I am going to just sell the 14 bolt axle.
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20 "The Town Truck"
Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272
Chaparralman1974 is offline   Reply With Quote
