Old 12-01-2022, 10:11 AM   #226
SCOTI
SCOTI's Avatar
Re: 65Custom Build Thread
Making some nice progress!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-01-2022, 10:32 AM   #227
Braunschweiger
Funny, I put everything back to the original, to mount the chains.
Good progress.
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 12-05-2022, 09:34 PM   #228
65Custom
Good progress.
I have decided to put in a latch into the tailgate and so no chains are going to be needed, so need to fill them in to make it look right when finished.
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=366677
I must be
65Custom is offline   Reply With Quote
Old 12-11-2022, 09:20 PM   #229
65Custom
Work continues
My Build Thread
I must be
Old 12-14-2022, 04:37 PM   #230
rcsbls2
]ust thinking, when you get roof welded on be sure and check condition of drains. Almost easy to not even notice them and with your replacement of your drip rails it easy to over look. That the cause of your rust in edges of a pillars and over windshield area. Roof water sits rust through and has access to other areas. Took pictures of mine but don稚 know how to attach.
07 Silverado Belltech 4-7 LS2 on stand
66 swb fleet in garage
my build thread 76 stepside (painting for buddy)http://67-72chevytrucks.com/vboard/s...d.php?t=645332
rcsbls2 is offline   Reply With Quote
Old 12-14-2022, 11:24 PM   #231
65Custom
Yeah hadnt thought about the drains and at this point Im not sure where they were, so if you do have pictures would be good to see where they were on yours, we still have yet to put sealer in the drip rail
My Build Thread
I must be
Old 01-15-2023, 04:09 PM   #232
65Custom
something else to ponder
My Build Thread
I must be
Old 01-16-2023, 06:08 PM   #233
caseyjones
New fuel filler location?
caseyjones is online now   Reply With Quote
Old 01-16-2023, 07:41 PM   #234
65Custom
yeah wanted to keep the exterior as much stock looking as possible and settled on putting it in the stake pocket
My Build Thread
I must be
Old 02-04-2023, 05:55 PM   #235
65Custom
Making progress getting it mocked up so we know how it is going to work, so far it works as we expected.
My Build Thread
I must be
Old 02-05-2023, 12:03 AM   #236
cwcarpenter98
cwcarpenter98's Avatar
Even though it isn't finished yet, I like that fuel fill door idea a lot
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 02-05-2023, 04:26 AM   #237
Braunschweiger
That looks great, very good idea.
Greetings Harald
My 62 build thread
Old 02-07-2023, 04:28 PM   #238
65Custom
One of the issues we are running into is the fuel fill is going to have to be a 1.5" fill and to get the hose run we will have to have the flexible fuel hose. Also it will have to go through the rear bed cross member so we will have to cut a notch or hole to connect to the tank
My Build Thread
I must be
Old 02-10-2023, 09:54 PM   #239
65Custom
This was dropped off the other day.
My Build Thread
I must be
Old 03-05-2023, 12:53 AM   #240
65Custom
A little update making some progress, fuel door a little further along, reshaped the the wheel well lip it was pretty beat up on both sides, re-welded the inner braces, top of the driver bed side needs to pushed back flat it is some how rolled up a little didn't notice that till we started working on it. Still need a patch at the top of bed side near the fuel door, looks like some one cut it for a piece of plywood to use a tailgate best I can tell both side of the bed have the same cuts, reset the drivers side and started working on the passenger bed side.
My Build Thread
I must be
Old 03-05-2023, 01:00 AM   #241
65Custom
Test fitted the fuel tank, a before pic of the passenger side wheel well lip and an after of the Driver side wheel well lip, both were a bit rough and how we mounted the fuel door hinge.
My Build Thread
I must be
Old 03-17-2023, 10:19 PM   #242
65Custom
Test mounted the dummy gas tank fill, want the truck to look fairly original, needs a little adjustment.
My Build Thread
I must be
Old 04-23-2023, 10:46 PM   #243
65Custom
Making mods to the tailgate, taking three different set of parts to make it work
put in a new bed header panel
My Build Thread
I must be
Old 04-23-2023, 10:55 PM   #244
65Custom
Mount of the catch side of the latch, the tailgate catch and links are made from two different sets of links one to get the right length on the links and the other for the mount, another plate is installed behind the catch to shift the catch and links towards the tailgate to make sure everything clears hopefully doesn't bind or pinch or chip paint when finished,
temporary hole cut for the latch handle
My Build Thread
I must be
Old 04-23-2023, 11:03 PM   #245
65Custom
Any thoughts on how these wheels look to everyone? I was hoping when I purchased these they would look a little more traditional with the front side spacing being inset more as far as the spoke location but they were not and now I see it is mainly due to how the wheel is made best i can determine, anyway let me know what you all think of these, Im thinking they may be replaced and something more traditional looking coming, to me they look like they belong on a late 80's to 90's model
I will say I think look ok here but not really the look I was shooting for and I think it would give a modern look to the truck, if I was doing more mods like flush glass, one piece side windows and smoothed dood handles etc they might look good with it.
My Build Thread
I must be
Old 04-23-2023, 11:38 PM   #246
Arne
Arne's Avatar
Those wheels aren't my faves either. But bear in mind that I went about as far the other way as you can go, 15x8 steelies with chrome hubcaps. So I may not be a good judge.
- Arne
Finished Project - 1964 C10 Stepside, mild restomod
覧覧覧覧覧覧
Arne is offline   Reply With Quote
Old 04-23-2023, 11:56 PM   #247
65Custom
The rims to me look like ones on my 2014 grand cherokee where they are biased towards the outside of the wheels for brakes and suspension clearance, I didnt know they would be made this way when they were ordered but I also feared it was a possibility due to the backspacing and the fear came true
these are two piece wheels but not made in a standard way where the center is placed in a hoop and then welded these seem that they are machined from a blank with limited spacing depending on the depth and then welded on to the hoop to make up the width
My Build Thread
I must be
Old 05-04-2023, 12:19 PM   #248
65Custom
Another update, a little more progress
My Build Thread
I must be
Old 05-04-2023, 06:52 PM   #249
FamilyTruckster65
Looking good. Will you be rewelding the seam on the tailgate?
FamilyTruckster65 is offline   Reply With Quote
Old 05-04-2023, 07:05 PM   #250
65Custom
Yes to do it right you really have to weld that up, since once it is cut you can move the bracket everything is mounted to so without the welds they would be a little lose
My Build Thread
I must be
