![]() Join Date: Dec 2009
208 Transfer Case Rebuilt Kit/ Bearing,Chain&Gaskets
Where is the best place to buy parts for my 208-transfer case?
I will be putting new seals and gaskets for sure. Probably a chain. I will tear it down first then order parts. So, bearings will probably get replaced also. I just bought one for spare parts. So I have Extra Stuff ![]()
![]() Join Date: Jun 2012
Re: 208 Transfer Case Rebuilt Kit/ Bearing,Chain&Gaskets
I got the rebuild kit for mine from torque king.
https://torqueking.com/search-result...roducts&page=3
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
Thank You
![]() I will check them out. I will tear it down and get a List. ![]()
All about them K’s
![]() Join Date: Jun 2014
I bought a kit from EBay about 4-5 years ago for my 205. It had all the consumables in it and was about $100.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
I did not think about e-bay. I will search it also.
Just to update.
After several days of research. From multiple places. I went with Torque King. Staff was very helpful, and the price was competitive. Shipping was free another key point I went with them. Although as an option ![]() ![]() They include {Shipping Assurance} ![]() You have the option to delete it. ![]() This sounds like a Good General Discussion Thread. ![]() I am making a fixture plate on a rolling table to build the Transfer Case. That way I don't have to roll around and wrestle with it ![]() Thanks for the input JJH Jimmy and 57taskforce ![]() ![]()
I just drilled a hole in an old 4x6 I had laying around and a scissor jack on the other other side to hold it while I worked on it. It worked good.
That will work
![]() I welded up a fixture to use on a floor jack years ago, To put a transfer case in cause of a no helper issue. ![]() Sometimes I have spare time at work, While my machine has long run times ![]() You heard the old saying (Idle Hands) ![]() So, this is where that began. ![]() Access to a milling machine behind the Big machine I run. And a scrap plate of aluminum. And then This. I will probably finish it up tomorrow. It's supposed to get up to 60 degrees. I will use threaded rod and spacers for the holding/leveling. My parts are scheduled to be here Tuesday. I hope to show my Nephew this process. That is part of the reason for the extra effort.
