Bench seat end spring replacements
I am trying to repair a seat spring that has the end support springs broken on both ends.Does anyone know if the LMC part # 30-3124 works on a on a 69-72 full foam seat? Their website says it is for 67-68. If the part will not work is there another source for the correct part?
Posted via Mobile Device |
![]() Join Date: Dec 2013
Re: Bench seat end spring replacements
Post a picture of what you have , I have some extra springs from different model seats Always post pictures with any questions you may have .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Here are some photos showing where the springs should be.
I'll post some pictures shortly .
This is the type spring you need for a full foam seat . I don't know of anyone reproducing them , Place a want to buy in the parts section or try your local interior shop and see if they have a generic replacment .
![]() Join Date: Feb 2011
Those used to be sold by USA 1 Industries 20308-part number.
You would get 4 springs back in 2018. I only found this listing from eBay for 2 springs for about $50. https://www.ebay.com/itm/23440082234...Bk9SR_Ko0e-_YQ
MusicMan70 1961 GMC Suburban |
Who Changed This?
![]() Join Date: Jan 2013
I went up to a hobby store and bought piano wire. I should have gone to an upholstery shop. Didn't cost much, but what a female dog to bend into shape!
Cut up an old box spring mattress to make one . Wasn’t easy to cut out it dulled out two steel bi-metal Milwaukee blades . And it was a bear to bend even in the vise
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 01-29-2023 at 06:04 PM. |
Does anyone have a photo of the correct spring attached to the frame? I have a spring type frame that I can use for parts. I have removed a few springs from it but I’m having a hard time getting the support I need on the end spring without getting in the way of the foam. I suppose I could both h the foam to get around the problem but I am trying to avoid it.
![]() Join Date: Dec 2009
What about these?
Link for spring kit: https://www.amazon.com/House2Home-Up...5037334&sr=8-7 Link for (Just ) clips: https://www.amazon.com/House2Home-Up...5037334&sr=8-6
![]() Join Date: Oct 2014
USA1 Industries has the springs that I use. I also double up on the end springs. I think that is why these are always broken, GM only had 1 per side. It just isn’t enough.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
I also have the original sized springs if you want to use those instead of the repop end springs. After looking at your seat frame, I see you can only use one per side.
You’re welcome to them.
#15 |
TKCR I just checked their website and could not find them.
Do you have an updated part number?
#16 | |
LMC has them also
#17 |
#18 | |
#19 |
#20 |
I appreciate all of the help on this. Does anyone know if the LMC springs that are linked will fit a 69-72 seat frame? It says 73-87 but it looks like it could work.
I took some springs out of the original seat in my truck, which is not the full foam seat, and bent them so I think they will work. The problem is they are a smaller gauge wire than the broken spring which was already apparently not strong enough since they are so commonly broken. I may have to see if I can figure out a way to use 2 springs as TXCR suggested. https://www.lmctruck.com/1973-87-che...eat-components |
#21 | |
#22 |
Try Bill's Truck Shop in Ontario, Canada. I linked the catalog for 67-72 parts below, I think the springs shown on page 47 (with price on page 48) are what you are looking for. When I rebuilt my bench seat I bought a length of spring, similar to what Getter Done posted above, from an upholstery shop and bent it into the correct shape. This was before I found out that Bill's sold these springs.
https://billstruckshop.com/wp-conten...2-2023-Jan.pdf |
#23 |
So. I purchased those side springs as well. But I need the long spring that that attached to.
#24 |
You’re missing that entire end spring. You’ll have to find a donor seat for that.
