Old 02-09-2023, 08:46 AM   #26
bsarts
bsarts's Avatar
Re: 65 C10 Family Connection
I'm glad you're saving it and looking forward to see what you do to it.
I'm sure the old man is tickled!
bsarts is offline   Reply With Quote
Old 02-09-2023, 12:42 PM   #27
bigmoe
bigmoe's Avatar
Originally Posted by FamilyTruckster65 View Post
A wrecking yard motor and transmission showed up about this time after the trucking company held it hostage for 6 weeks. It originated in Texas and just needed to make it to Oregon.
Somewhere along the line it broke loose from the pallet and rolled around some amount. It was bruised to put it mildly.
Make sure you let the wrecking yard know their shipping pallet was inadequate.
bigmoe is offline   Reply With Quote
Old 02-09-2023, 08:46 PM   #28
FamilyTruckster65
Pulled a few more parts off so that I could pressure wash all the mud off.
FamilyTruckster65 is offline   Reply With Quote
Old 02-09-2023, 08:47 PM   #29
FamilyTruckster65
Found Dads way of repairing a hole in the muffler. A large soup can and a hose clamp.
Old 02-10-2023, 09:32 AM   #30
JohnIL
JohnIL's Avatar
This is a cool project. With all of this truck's family history, it definitely deserves to be back on the road.
John
1965 C10 Long Bed Fleetside
SBC 350 and Saginaw 4 Speed
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=838676
JohnIL is offline   Reply With Quote
Old 02-10-2023, 10:43 AM   #31
rbruno68
Love the soup can fix. Use what you got right? I am still amazed at the condition of the truck after sitting all those years. From what I can see, the cab looks in very good shape. Is it as good underneath? Great project.
rbruno68 is offline   Reply With Quote
Old 02-10-2023, 08:19 PM   #32
FamilyTruckster65
The ol truck does have rusty areas in the cab. I agree it does look really good until you start digging in to it.
The roof and hood have very little paint left. The roof has no bubbles or perforations. The hood had a few in the very lower seam at the front.
Old 02-10-2023, 08:21 PM   #33
FamilyTruckster65
The door bottoms right on the weather strips will need some love.
Old 02-10-2023, 08:23 PM   #34
FamilyTruckster65
Drivers side under the floor mat.
Old 02-10-2023, 08:27 PM   #35
FamilyTruckster65
Where ever the padding was it help moisture.
Old 02-10-2023, 08:30 PM   #36
FamilyTruckster65
Passenger toe board has separated
Old 02-10-2023, 08:33 PM   #37
FamilyTruckster65
This did catch me by surprise..
Old 02-10-2023, 08:34 PM   #38
FamilyTruckster65
It did rust through the back of the cab.
Old 02-11-2023, 11:29 PM   #39
FamilyTruckster65
cleaning up the frame.
Old 02-13-2023, 06:49 PM   #40
FamilyTruckster65
After ALOT of elbow grease the front cross member is looking pretty good.
Old 02-13-2023, 11:28 PM   #41
cwcarpenter98
cwcarpenter98's Avatar
Yup, I think your truck will handle much better than stock once you get it all back together
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 02-14-2023, 08:10 AM   #42
joesscamaro
Whoa...that did clean up nice! What's the details? Sorry if I overlooked them in previous posts.
joesscamaro is offline   Reply With Quote
Old 02-14-2023, 12:03 PM   #43
FamilyTruckster65
Test fitting. I am pleased with the quality of these parts. Their customer service is top notch.
Old 02-14-2023, 12:06 PM   #44
FamilyTruckster65
Met a forum member, Lostmy65, that had a donor cab available for a few pieces to be recycled into our truck.
Thank you 65!
Old 02-14-2023, 12:11 PM   #45
FamilyTruckster65
NoLimit wideride. I have and do fabricate things myself, but sometimes you need to look at what you are trying to accomplish and weigh that against what may already be out there.
These are a well reguarded part that saves alot of time that I can be productive elswhere.
Old 02-15-2023, 08:21 PM   #46
FamilyTruckster65
OOOHHhhh, Shiney!
SpeedEngineering. They look pretty well made.
Old 02-16-2023, 09:32 PM   #47
FamilyTruckster65
Started cleaning up the rear of the frame. The trailing arms were very rusty from being on/in the ground. Fortunately the suspension kept the frame and body from being in contact with the dirt.
Old 02-19-2023, 01:22 AM   #48
FamilyTruckster65
More cleanup and rivet removal for the different crossmembers. Removing rivets is not one of the funner jobs.
Old 02-20-2023, 12:33 AM   #49
FamilyTruckster65
I have decided that the Chevy is too far gone to mess with. I am now going to focus my energy on stepping up the Gator with the 6.2 and 8 speed.
Has anyone seen a bolt on kit for this? JCWhitney maybe?
Old 02-22-2023, 09:33 AM   #50
FamilyTruckster65
This combo was from a Silverado. The stock oil pan could have been made to work with some compromises, like lifting the engine on taller motor mounts, but it is also pretty deep. This pan is modeled after the Camaro pan.
With the adapters that take the stock Chevy small block mounts on the truck motor you need to loose the vacuum pump. Also the vacuum pump location is going to be the new mount for the power steering pump.
