#151 |
![]() Join Date: Jun 2019
Re: My New Truck
Bought some new head gaskets. and bolted on the heads.
http://67-72chevytrucks.com/vboard/s...d.php?t=791250 |
#152 |
Re: My New Truck
Some more pics.
#153 |
Re: My New Truck
Now the latest debacle.
My engine came with the 4L60 Flex plate, with a 6.0 LQ4 (yes I know rather odd). Rather than drill it out I decided to get the correct 6.0 LQ4 flex plate (Silver one-pictured below) I bought the, what I thought was correct 4L80 flex plate. A Chinese 6.0 LQ4 ATP flex plate. After I get it and get it installed (now, its beyond the return period) then I read various sources who say, ATP flex plates (read Chinese) are junk and they SHOULD not be used, as you risk serious transmission damage if used. https://youtu.be/sp6Wjtve3D0 So now, I had to go out and source a better flex plate. Thus I stepped up and bought a TCI flex plate.
http://67-72chevytrucks.com/vboard/s...d.php?t=791250 Last edited by Factory Guy; 11-16-2022 at 11:45 AM. Reason: add photos |
#154 |
Re: My New Truck
Last Summer ls1nova71 pointed out to me that my digital dash I was building wasn't going to have the same font spacing on the speedometer like I had originally thought. SINCE I am switching to a LS I am going to need a digital Speedometer.
You can read all about ls1nova71 sweet inexpensive Digital Speedometer conversion at: http://67-72chevytrucks.com/vboard/s...d.php?t=512751 So the original Squarebody Speedometer look like this
#155 |
Re: My New Truck
Just realized the S-10 Digital Speedo is just way to big for my Squarebody instrument cluster housing as it would require cutting out the plug, that powers the entire instrument cluster. Time to look for another option...
#156 |
Re: My New Truck
Ahh man..... After that effort!?
#157 |
Re: My New Truck
I was looking at the oil pan pictures again and wondering about ground clearance. Do you know how far it will hang below the factory crossmember?
Evan B. |
#158 |
Re: My New Truck
Just did a great Brake upgrade to my truck, I am elated with how happy I am, and how it turned out (especially for the money spent!)
If you want to see my post of it: http://67-72chevytrucks.com/vboard/s...d.php?t=834273
http://67-72chevytrucks.com/vboard/s...d.php?t=791250 Last edited by Factory Guy; 01-01-2023 at 12:51 PM. |
#159 |
Re: My New Truck
Stepped up and bought a new factory dash pad (not one of the Cheap ones from LMC or Classic truck parts), from Cobin's Custom Upholstery.
This was a GM OEM metal dash that got recovered (not one of those Urethane dashes), although the color is slightly different I guess I will live with it since it looks so much better than the other cracked mess. I was going to redo my own, but since I am so far behind on my projects, I decided to farm this one out. Got it installed today.
#160 | |
Re: My New Truck
If you use the other brands you end having to buy a new oil pan. pic is the TEJAS steel mount.
http://67-72chevytrucks.com/vboard/s...d.php?t=791250 Last edited by Factory Guy; 12-21-2022 at 06:16 PM. |
#161 |
![]() Join Date: Oct 2014
Re: My New Truck
Dash looks good!
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
#162 |
Re: My New Truck
Looking now at swapping in a 1993-1997 Chevy G10-30 Digital van Speedo.
The first picture is the van speedo (0-85mph), yes I will have to get the graphics redone (like I did with the Tach) to match a Square. But the layouts pretty much mirror each other. 2nd picture is the Square's face on the van Speedo. Now to figure out a way to make a nice cut in the back of the Square plastic gauge housing to fit the much smaller van speedo. It still will require a deeper hole than the Squares conventional Speedo. Versus the very large S-10 speedo.
#163 |
Re: My New Truck
#164 |
Re: My New Truck
The latest debacle:
I went to start the engine and primed the engine with oil prior to starting it about 2 days later (Still have not started it yet), I noticed a pretty good sized oil spot (10" in diameter) under the power steering pump area (if it was installed). Upon further inspection I am finding that the oil seems to been leaking between the oil pan and the block right below the negative ground cable bolt? See yellow arrow in picture. So now I am pulling the oil pan and installing a new gasket. Thank God the engine wasn't in the truck. This why I like running them outside the vehicle BEFORE installing them!
http://67-72chevytrucks.com/vboard/s...d.php?t=791250 Last edited by Factory Guy; 02-03-2023 at 12:32 PM. Reason: spelling |
#165 | |
Re: My New Truck
Engine Oil leak was probably my fault not the gasket or anything else. The oil pan bolt in that area was not even close to being tight. Anyway I replaced the oil pan gasket and cleaned all of the surfaces, just to be safe. Oil is in it, just waiting on a nice day to start this so I can get it installed. All oil pan bolts are now torqued to 18 ftLbs.
#166 |
Re: My New Truck
Truck looks excellent! Keep up the nice work.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10 | Oscar the 70 C10 - C10 Concept/Development Photos: Master Thread |
#167 |
Re: My New Truck
So if enough wasn't going on with my truck I decided to add something else.
Since my truck didn't come with Cruise or Tilt, I decided to add a new steering column to correct that. And since I do NOT want any after market stuff. I had to add a GM Tilt/Cruise unit to my truck. So the process has started. I bought a used unit from a fellow member here on 67-72chevytrucks.com, this unit came out of a 1977 Camper Special. But since I didn't know the history of this steering column, I decided it needed to be rebuilt. I knew IT WASN'T going to be me. So after a bunch of research I decided to have Steering Columns galore do the rebuild. Here's the new (to me) unit installed on the first day. The process has started.
http://67-72chevytrucks.com/vboard/s...d.php?t=791250 Last edited by Factory Guy; 03-20-2023 at 09:03 PM. |
#168 |
![]() Join Date: Apr 2018
Re: My New Truck
Another fine upgrade. Tilt column is a nice feature… and just yesterday I was kicking myself for not adding cruise. 120 mile round trip and cruise would’ve made it that much sweeter.
"Sweet Pea" 1975 Cheyenne 20 http://67-72chevytrucks.com/vboard/s...00#post8477900 "Bourbon" 1975 Suburban ScottsdaleSOLD https://67-72chevytrucks.com/vboard/...49#post8769049 ”Otis” 1970 C10 SWB -SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=762766 ”Chebby” 1962 Impala LS/TKO-500 http://www.pro-touring.com/threads/1...2-Impala-Build |
#169 |
Re: My New Truck
#170 |
Re: My New Truck
Tilt AND Cruise Column now installed.
Since somebody had cut the cruise wires, inside the steering column, prior to my purchase of the column. It was necessary to buy a new Cruise Switch (see photo's below-somebody cut it so close to the stalk it made it unusable). The place where I got my Steering Column redone, Steering Columns Galore (SGC) said they had no sources for new Switches. I finally found a repop that looks identical to the factory units. Once the LS goes in it will get wired up. EDITED: 3/13/2023 So i go to wire up my ignition switch, nothing matches the old stock non tilt/non cruise ignition switch. So long story is the wiring loom under the dash to the IGNITION SWITCH remains the same (it is NOT necessary to re pin or anything), the wires AND connectors just get moved. So in the Ignition switch photo below (the blue ignition switch=not mine just one I grabbed on the internet). The rear plug "POS 1" needs to be moved to "POS 2", AT the SAME TIME they get inverted (turned over and plug right into the ignition switch with NO REPINNING required. The front plug POS 2 needs to be moved to POS 1 AND INVERTED, NO REPINING REQUIRED.
http://67-72chevytrucks.com/vboard/s...d.php?t=791250 Last edited by Factory Guy; 03-13-2023 at 05:42 PM. Reason: Clarification |
#171 | |
Re: My New Truck
One of the main reasons I went with DBW.
#172 |
Re: My New Truck
I’m DBC on the Cheyenne. I have DBW on my 62 Impala 6.0 swap and I’ve always felt like there’s a tiny delay in throttle response. You can barely notice it… but it’s like when you’re watching a movie and the sound is off by just a fraction of a second… you hear the words and the actors mouth is just slightly off? Lol same feeling and it drives me nuts. So I went DBC on the truck.
#173 | |
Re: My New Truck
It didn't have it, but the only way I was going to do it was with a FACTORY unit.
#174 | |
Re: My New Truck
Needed to add the photo's since I can't do it in my old post...
#175 |
Re: My New Truck
The ENGINE now runs! Started it on the stand to see if it would run and it did! so now its time to start the transplant.
| Bookmarks |
