Old 02-03-2023, 03:53 AM   #1651
Wikid61
Wikid61's Avatar
Re: Post your 60-66 craigslist finds
https://slo.craigslist.org/cto/d/arr...583955575.html 1966 Chevy C10 - $1 (Arroyo Grande) 1966 Chevy C10 pickup, short bed, fleetside, big back window, 540 c.i. bbc with twin turbos, conservative 10 lbs boost, Dart 345 aluminum heads, Holley Super Sniper Stealth EFI, blow through throttle body, Holley Sniper tunnel ram, Comp Cams hyd roller cam and rockers, MSD 6AL box, MSD Magnetic pickup distributor, built turbo 400 trans, 2600 stall converter, Gear Vendors Overdrive, 9" PEM Ford rear w/3.70 POSI, front 6-piston Wilwood disc brakes, GM rear disc brakes w/e brake, CPP rear coilovers with tubular trailing arms, Riddler 605 20" wheels with Nitto rubber, electric parking/emergency brake, all polished 3" stainless exhaust, with electric cutouts thru front fenders and full exhaust with bullet mufflers exiting thru the bed, rear bed mounted radiator with dual electric fans, electric water pump runs 180-190 degrees, front mounted 3" air to air intercooler for the turbos, custom butcherblock rear bed floor made of Hickory and Black Walnut inserts mounted to an electrically controlled frame, rear mounted Tanks aluminum fuel tank with Aeromotive 1000 intank fuel pump, bed mounted Optima yellow top battery underneath easily removable bed floor panels, interior seats/console/door panels by TMI Products, One Piece Products door glass(no windwings) with power window conversion, Custom Autosound Bluetooth stereo, Dakota Digital VDX gauges with GPS speedometer, Ron Francis wiring harness, bed sides, tailgate, headboard and front fenders all new steel, fiberglass lift off hood, satin paint, and much more I've probably forgotten about. Runs perfect, shifts hard, lots of eyeball and sounds threatening. Less than 1100 miles at this point. Have clean CA title in hand. $85k . Reply to craigslist with contact information. Driving / walk-around / cold start video on youtube.https://youtu.be/ds9yFK99g04, https://youtu.be/p_VpySeNi6I . 1966 twin turbo c10
"Envy is a declaration of inferiority". Napoleon Bonaparte.
Wikid61 is offline   Reply With Quote
Old 02-03-2023, 04:17 AM   #1652
Wikid61
Wikid61's Avatar
https://sfbay.craigslist.org/nby/cto...584352878.html 1965 C10 Stepside - $16,500 (Petaluma) Freshly painted 1965 Chevy C10, new oak bed, we 22” transports with new rubber. Fresh drum brakes all the way around, runs and drives great. New aluminum radiator, carburetor, gas tank relocated under bed.
Old 02-06-2023, 08:25 PM   #1653
Wikid61
Wikid61's Avatar
https://sfbay.craigslist.org/eby/cto...585793952.html 1963 short bed c10 - $12,000 (concord / pleasant hill / martinez) 350
700r4
Short bed
New brakes
New tires
Vintage slot mags
Manual steering
Manual brakes
Old paint
Lights work
Runs drives stops
$12,000.
Old 02-17-2023, 04:41 PM   #1654
forestb
forestb's Avatar
This is quite a deal for someone that has some room. Three panel trucks for $7000
https://losangeles.craigslist.org/an...589239338.html
forestb is offline   Reply With Quote
Old 02-18-2023, 06:31 PM   #1655
karlbenz
That one didn't last long
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
1990 Chevy Bus 8.2l fuel pincher 8800 miles
1993 Ford F350 crewcab 7.3idi nonturbo ZF5 Transmission Running on WMO
karlbenz is offline   Reply With Quote
Old 03-18-2023, 07:40 PM   #1656
jocko
jocko's Avatar
66 GMC 1/2 ton Custom Cab bbw - don't see these every day.. Rough condition but only $3K. Would be a gem restored.
Old 06-06-2023, 09:04 PM   #1657
forestb
forestb's Avatar
I know that big back window short bed fleet sides are popular right now but prices are becoming a little ridiculous. Especially for a truck that doesn’t run and looks to have rusted rockers.
https://losangeles.craigslist.org/sg...629679624.html
Old 06-06-2023, 09:58 PM   #1658
Arne
Arne's Avatar
Wow. I may have to raise the asking price on my truck after seeing that.
Or not, since I'm trying to stay somewhat sane about that...
- Arne
Finished Project - 1964 C10 Stepside, mild restomod
Arne is offline   Reply With Quote
Old 06-06-2023, 09:59 PM   #1659
Killer Bee
Killer Bee's Avatar
ca truck
straight body
minimal rust
factory short bed
factory big window
factory a/c
factory v8
factory interior
unmolested
knee knocker cab w/o pig nose hood
I suspect it could be fairly haggled to $15k and doesn't last long
Old 06-07-2023, 10:43 AM   #1660
forestb
forestb's Avatar
Originally Posted by Killer Bee View Post
ca truck
straight body
minimal rust
factory short bed
factory big window
factory a/c
factory v8
factory interior
unmolested
Sense you put it that way I want to buy it
Old 06-07-2023, 01:25 PM   #1661
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
I don't think that that is "factory" AC. Also the heater box and receiver dryer are missing. Cute little truck, though.
~Steven
Simi Valley, CA
Old 06-07-2023, 02:59 PM   #1662
GranPanteraRoja
GranPanteraRoja's Avatar
I think it's dealer installed AC but a universal "factory approved" unit as if I recall it was an available accessory in pre-'64 trucks. In '64 we got the C10 specific design, still dealer installed, then '65+ onward it was factory installed.
GranPanteraRoja is offline   Reply With Quote
Old 06-07-2023, 03:06 PM   #1663
forestb
forestb's Avatar
All I can say is that is one time I would not mind sitting in the middle.
Old 06-07-2023, 04:38 PM   #1664
Killer Bee
Killer Bee's Avatar
although it's not really my type, that truck checks a lot of boxes as far as the market goes
my apologies if I misspoke on the a/c, I wasn't sure when they started in dash
but still, even if it's oem installed at the dealer it's a pro not a con
and I'm right there with you Forest!
Old 06-10-2023, 10:46 AM   #1665
CKfan
FBMP find
Check out the rims on both trucks selling for 7K!
https://www.facebook.com/marketplace...3-344ac642db70
CKfan is offline   Reply With Quote
Old 06-10-2023, 12:27 PM   #1666
jocko
jocko's Avatar
Originally Posted by CKfan View Post
FBMP find
the seller clearly understands our affliction.. "Blue one is about 2/3rds of a truck but would be perfect to put behind the shop and never think about it again"
Old 06-14-2023, 09:10 PM   #1667
Lokin4AReason
Lokin4AReason's Avatar
I know its not a craigslist find but a fakebook one
https://www.facebook.com/marketplace...1942090228679/
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 06-16-2023, 11:14 AM   #1668
Micmac
Micmac's Avatar
Greensboro, NC my hometown!! Nice find.
1963 Chevrolet C-10 "Ginger"
1970 C-30 Dump Truck "Scarlet"
2019 Chevy Silverado 2500 Z71 LTZ
1947 Indian Chief Roadmaster with Sidecar.
2012 Indian Chief Serial #002 of 110 built in '12
2016 Indian Chief Roadmaster
Micmac is offline   Reply With Quote
Old 06-16-2023, 11:31 PM   #1669
CKfan
Good running 292 4 spd transmission and transfer case for sale WA $500!!
https://www.facebook.com/marketplace...9982427035071/
Old 06-20-2023, 09:08 PM   #1670
forestb
forestb's Avatar
Price dropped like a rock.
https://losangeles.craigslist.org/sg...634720048.html
Old 06-23-2023, 08:02 PM   #1671
forestb
forestb's Avatar
This guy is super motivated to sell.
https://losangeles.craigslist.org/sg...635902080.html
Old 06-25-2023, 02:21 AM   #1672
Lokin4AReason
Fotos(s) from the link above
Thats an interesting setup on that rear bumper w the trailer hitch
Could use that air cleaner if its for one for a four barrel . . .
Old 06-27-2023, 06:18 PM   #1673
jocko
jocko's Avatar
65 K10 stepper ebay $20K starting bid
Old 07-18-2023, 02:12 PM   #1674
The Rocknrod
Moderator
The Rocknrod's Avatar
1960 Chevy Apache Fan Shroud and Radiator.
https://www.facebook.com/commerce/li...are_attachment
Old 07-23-2023, 10:38 PM   #1675
jocko
jocko's Avatar
65 K10 $6K
