Old 02-12-2023, 04:54 PM   #1
csa daddy
csa daddy's Avatar
Tubular control arms
Does anyone in here know if tubular control arms for a square body chevy are the same for a 1/2-1 ton And only difference being the ball joint itself ?
csa daddy is offline   Reply With Quote
Old 02-12-2023, 07:11 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Tubular control arms
the control arms would be different they would be bigger the heavier you go
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 02-15-2023, 12:26 PM   #3
SCOTI
SCOTI's Avatar
Not necessarily. 'Tubular' indicates aftermarket. The answer would be dependent on the arm manufacturer.
As for factory GM stamped-steel a-arms (pre-88 body style excluding Burbs?Blazers/CC's)....
GM 1/2 ton control arms for earlier (pre-73) trucks will swap over to later (post-73) x-members.
The post-72 HD trucks continued use of the earlier style bushings.
Post-72 1/2 ton trucks got the car style bushings. Different OE bushings require the different/appropriate arms.
Lower BJ's are larger on the HD apps but the arms themselves will still swap over.
Upper BJ's for 1/2 ton & larger have the same footprint as far as mounting to the arm so they will interchange.
*The BJ mounting 'footprint' changed w/the introduction of the OBS/GMT400 series trucks so the upper arms are either 1/2 ton spec or 3/4 ton/up spec.
In summary, it depends on what you're trying to accomplish.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-18-2023, 07:07 AM   #4
csa daddy
csa daddy's Avatar
Thank you sir that's exactly what I was thinking but wanted some other opinions on on it
