Old 02-19-2023, 01:53 AM   #1
dagnabbitt
dagnabbitt's Avatar
J76 Park Brake Prop Shaft
Hi everyone, I thought I would post over here since despite the fact that my truck is a 1968 (build thread at bottom), it has an option that is more commonly found on 1966 and earlier trucks.
I've been trying to figure out for a few years, now, why and how my truck would have what appears to be a 1966 transmission with this unusual option - you can read about it here if you are interested - but with not too much information available, I have simply decided in the interim to accept it and try to put it together so it is functional.
I found the parts I was missing on this forum - the springs and shoes and whatnot - but I suspect that the hand lever I am using is incorrect. I think based upon my reading that it is probably off a C60 or COE or something: it is too long and it hits the dash.
Pictures of this set up in 1965-66-ish trucks show a much shorter lever. I thought maybe this was just an optical illusion or a difference in the height of the trans hump in these trucks or the distance between it and the bottom of the dash. But now I am pretty sure.
Looking for opinions on this, and maybe some pics and measurements, if anyone has them, of the handbrake lever in a light-duty truck with this option. Thanks in advance.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 02-19-2023, 06:07 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: J76 Park Brake Prop Shaft
This thread may lead you to the information you want - http://67-72chevytrucks.com/vboard/s...d.php?t=622541
Old 02-19-2023, 11:19 AM   #3
dagnabbitt
dagnabbitt's Avatar
Thanks, I did use the pics in that thread as reference to put my brake together, however I am still unsure if I have the correct hand lever.
Looking at those pics again I wonder if the dash is just higher up in a 60-66 than in my 68.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
