56 - autocross
Gas Pedal - Kind of a poll - 55-59
55-59 Chevy Trucks
What aftermarket gas pedal are you using? Any good? Suggestions welcome. |
Re: Gas Pedal - Kind of a poll - 55-59
Here's what I have in my 56, 2nd series. The mounting surface on the truck floor had to be alterered with a offset piece (I made) in order for the gas pedal to be inline.
Speedway Motors | #91655013 Speedway Billet Aluminum Accelerator Throttle Pedal
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
have you modified the firewall and floor area for engine clearance or do you have a stock scenerio? I ask because sometimes the mod has decreased floor space in the accel pedal foot well area. are you looking at drive by wire, solid linkage style or a cable operated set up? a pic of your floor area may help.
I might prefer something a little less flashy but this does the job.
https://67-72chevytrucks.com/vboard/...1&d=1677080537 |
#5 | |
![]() Join Date: Mar 2007
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
I've got a Lokar knockoff that should sit and work like the stock pedal that has the cable on the outside of the firewall.
This being the 240 dollar real deal but I didn't pay near that for the as my dad used to say "almost as good" unit that probably came from Hoffman group. The main thing well beyond appearance is that the gas pedal has to be comfortable to drive with. It doesn't matter how great looking it is if it gives you cramps in your leg, ankle or foot or is uncomfortable to drive with. I think I have the pedal out of a 76 Mustang II that I scrapped out in the truck now. That was after a half dozen other pedals over the years one lasting one day before I took it back out and threw it in the trash barrel. I think this is the cheaper one that I bought off Ebay quite a while ago eBay item number:313768029638
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 02-22-2023 at 05:36 PM. |
Lokar “Lakester”, I had to fab up a mount to get it where it was comfortable…
lokar floor mount.
should have mounted it a little higher to allow for the underfelt and carpet but it works great. Q |
blacksheep, that looks REALLY nice. not just the pedals, the whole thing. I like how you have spaced the pedals apart enough to be prctical, and the carpeting turned out like it was factory made. is the centre section a removeable plate for access to the engine area, or just a detail?
#10 | |
The center piece seemed like the best work around because of all the angles and weird contours where everything converges. It was shaped with a steamer and glued into place, overlapping the raw edge of the main piece of carpet where it was cut to accommodate the hump in the firewall. There are pictures in my build thread that illustrate how it was done, better than I can explain it. Last edited by Black_Sheep; 03-10-2023 at 09:03 PM. |
black sheep, your build is show quality. very nice attention to detail. you should be proud.
![]() Join Date: Aug 2010
I have the Lokar Pedal and I want the stock look , so I found if you grind off the nub on the backside of the stock pedal it will slip over the Lokar Pedal perfectly and a couple small screws will secure it to the Lokar pedal.
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
![]() Join Date: Apr 2016
Here's the pedal I used. It's from Lokar and designed for a C10, but worked great in my application.
I am using the factory GM electronics, steering column, etc. from a mid 2000s Yukon in my 59.
To get the drive by wire gas pedal to fit, I had to weld a bracket to the steering column and attach the pedal there.
Brian Project: 1959 Chev Apache Fleetside |
