![]() Join Date: Apr 2016
What are these shelves inside the bed for?
Do these shelves inside the bed side hold some sort of box or accessory? Or did the designer just think that would be cool looking? This is my new-to-me 1995 S-10 pickup.
BlahBlahBlah
Re: What are these shelves inside the bed for?
I think you can span the bed side to side with boards or? for whatever reason you might come up with
![]() Join Date: Dec 2009
Yeah, I have seen people that do this.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Makes it possible to haul sheetrock and other 4 foot wide sheet goods.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
You put 2X4s across the box, it gives you a wider loading area than between wheel wells. You can also put OSB or plywood sheets to make a wider flat area.
Yes, interesting.
I downloaded a copy of the owners manual today and found a part about Two-Tiered Loading: Two-Tiered Loading By positioning four 2” x 6” wooden planks across the width of thepickup box, you can create an upper load platform. The planks must be inserted in the pickup box depressions. The length of the planks must allow for at least 3/4“ bearing surface on each end of the plank. When using this upper load platform, be sure the load is securely tied down to prevent it from shifting. The load’s center of gravity should be positioned in a zone over the rear axle. The zone is located in the area between the front of each fenderwell and the rear of each fenderwell. The center of gravity height must not extend above the top of the pickup box flareboard. |
| Bookmarks |
