Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 02-26-2023, 08:50 PM   #4
VictoriaHardware
VictoriaHardware's Avatar
Re: C80 Spec Tags
Originally Posted by factorystock View Post
Thanks for sharing. The standard C 80 looks very similar to a heavy duty C 60, which was known as the C 60H. The narrower fenders indicate it has the 7K front axle. The wider fenders kick in at 9k. Here is some info on standard and optional equipment.
Excellent information factorystock, thanks. Is that the "Specification Book" ? I can now reverse-engineer the cost of the truck. Wasn't sure of standard vs. optional equipment before. Is the MSRP of the C8503 base model also there?
C10 - C90 Bill:
GVW is 25,000 from the Trim Tag
Engine is F40 (409 ci) with the original Packard date-coded spark plug wires
Trans is the Close-Ratio Spicer 5 speed- 5756B
Truck had 19k miles when it was retired from active service in 1998. Now has 28k miles- a lot of car shows.
VictoriaHardware is offline   Reply With Quote
