Old 01-29-2023, 09:15 PM   #851
Kronald_70GMC
Kronald_70GMC's Avatar
Re: My 1970 GMC “Project Splice”
I also was able to get some more welding and grinding done on the seat bracket. I have welded and ground down and finished the bottom of all the tabs. Ready for some full work down the road.
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 02-05-2023, 08:10 PM   #852
Kronald_70GMC
Today I managed to get the rest of the feet finished up on the passenger bracket. I also cut a v between the angle irons and the brackets and ran another weld across to make sure that they are strong. I was about 30 minutes shy of being able to complete the grinding on the passenger bracket. My compressor can't keep up anymore since my secondary tank gave up on me so it's slow going. Between waiting for the compressor to catch up, I took a square nut that was given to me by my dad for the one mounting point I needed to add and shaped it to look like the factory ones. Hopefully soon I can flip the cab on its nose for the last time.
Kyle
IG: kyle_ronald
Old 02-06-2023, 11:12 PM   #853
Kronald_70GMC
I'd have to say it looks pretty good in there with the other two nuts.
Kyle
IG: kyle_ronald
Old 02-19-2023, 09:20 PM   #854
Kronald_70GMC
It's been a little slow the last few weeks on the truck but I maged to get some stuff done. I have completed all the welding and grinding on the seats so that is a huge step in the right direction. Today I was cleaning up a few odds and ends and got the passenger side cab mount plate welded back in as well as the last mounting plate for the passenger seat. I also got the driver side cab mount plate prepped and ready to weld in. Hoping to have the time to get that and the driver seat plate welded in tomorrow. After that, I will have to figure out some sort of firewall support that I can use to tip the cab back onto its nose and finish the underside completely.
Kyle
IG: kyle_ronald
Old 02-20-2023, 02:54 PM   #855
Kronald_70GMC
Got those last two pieces welded in. Now I just need to make some sort of cradle for the firewall so that when I flip in on its nose, I have a way of securing it in place on my cart. I've got some scrap lumber to work with so I think I can come up with something.
Kyle
IG: kyle_ronald
Old 02-26-2023, 08:03 PM   #856
Kronald_70GMC
Firewall craddle complete! Now I just have to do a good cleanup around the garage and find a bunch of guys to help me flip it to its nose!
Kyle
IG: kyle_ronald
Old 02-26-2023, 09:33 PM   #857
May70
May70's Avatar
What is a firewall cradle?
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
Old 02-26-2023, 09:37 PM   #858
Kronald_70GMC
I made it so that when I flip it onto the firewall, it will help to evenly distribute the weight. It will also give me a point to attach it to my cart so that I don't have to worry about it falling over.
Kyle
IG: kyle_ronald
Old 03-05-2023, 10:52 PM   #859
Getter-Done
Getter-Done's Avatar
Great Idea on the cushion when you roll it
It is looking great.
84 Chevy K-20
Old 03-06-2023, 06:06 PM   #860
Kronald_70GMC
Thanks man! It's going to feel so good to have the bottom of the cab completely finished.
Kyle
IG: kyle_ronald
Old 03-10-2023, 12:36 PM   #861
Kronald_70GMC
I scored this today locally! It has a bit of a curve but I'm pretty confident that I'll be able to straighten it. The worst part is the large dent in the lettering but I think I can fix that up too. The best part is I haven't seen any rust holes or signs of one starting.
Kyle
IG: kyle_ronald
Old 03-10-2023, 09:54 PM   #862
Kronald_70GMC
Got is straightened! Used a jackall, some wood blocks and a scissor lift. We ended up lifting up the scissor lift to get enough weight on it. Super happy with this gate
Kyle
IG: kyle_ronald
Old 03-11-2023, 07:54 AM   #863
72 tigger
72 tigger's Avatar
Nice work on the tailgate!
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 03-11-2023, 11:47 AM   #864
cornerstone
cornerstone's Avatar
Very nice score and work on that rust free gate!
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 03-11-2023, 11:55 AM   #865
Kronald_70GMC
Thanks guys!
Kyle
IG: kyle_ronald
Old 03-19-2023, 08:14 PM   #866
Kronald_70GMC
Today was the first time in a couple of weeks that I actually got to work on the cab again. I've decided to wrap up a few loose ends on some other items within the cab before I flip it on its nose. Mostly that decision was due to a bunch of materials and such all over my garage and in my way. Today I added some more steel to the structure of my "behind the seat" box. There is still some more metal needed before it is completely done but I needed to see how this was going to work first. I cut my pressboard to fit and got it all screwed in place to get an overall idea of how it will look. There will be more work on this to come as I need some more backing (steel) to screw in a few loose areas and I will eventually make some speaker enclosures and a sub enclosure that will mount from behind. I'm pretty happy with the outcome thus far.
Kyle
IG: kyle_ronald
Old 03-19-2023, 08:19 PM   #867
chewychevy67
That looks smooth
chewychevy67 is offline   Reply With Quote
Old 03-19-2023, 08:21 PM   #868
Kronald_70GMC
Originally Posted by chewychevy67 View Post
That looks smooth
Thank you!
Kyle
IG: kyle_ronald
Old 03-20-2023, 11:18 PM   #869
Kronald_70GMC
Just wanted to throw in a picture without all the mess in the cab.
Kyle
IG: kyle_ronald
Old 03-21-2023, 05:55 AM   #870
72 tigger
72 tigger's Avatar
Looks very clean! Should work well
71 C10
72 K20
72 K10 Super
Kirk
Old 03-21-2023, 02:18 PM   #871
Kronald_70GMC
Thanks!
Kyle
IG: kyle_ronald
Old 03-31-2023, 08:41 AM   #872
KyleSeal
KyleSeal's Avatar
Great thread, really liking the work. You've come a long way with the welding and it looks great! Isnt it interesting how many fractures and stress cracks seats get in their life? My bench needed nearly every spot weld redone and had many stress cracks
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 03-31-2023, 10:30 PM   #873
Kronald_70GMC
Thanks for the compliments! I'm sure it would be wild if a person could see everything these trucks have gone through over the years.
Kyle
IG: kyle_ronald
Old 04-02-2023, 07:48 PM   #874
Kronald_70GMC
I pulled my box back out today and started adding the required support pieces I need to properly fasten the press board the rest of the way. I also added some pieces to pickup the fiberglass corner sections. I plan to use nutserts for those. I didn't quite have the time needed to get it put all back together as I have a few more pieces to put in and need to weld everything on the back side yet.
Kyle
IG: kyle_ronald
Old 04-04-2023, 11:26 PM   #875
Kronald_70GMC
Tonight I went over to my parents place and helped my dad bleed the brakes on his '69. We were hoping to take it to the local car show this weekend but after going for a test drive, we will not be able to take it. Unfortunately a botched transmission rebuild is making it very hard to drive anywhere. It revs at 2500 rpm at only 40 MPH along with plenty of other issues. At least the brakes are now nice and solid. Here are some pictures of the truck
Kyle
IG: kyle_ronald
