Re: Rockwell T-221 Transfercase Slop - Need Advice
I checked out you build thread that's already one sweet ride.
How are the splines on your input shaft? Since you have a 67 you can still get the splined adapter sleeve for it. https://www.transmissionpartsdistrib...2-ton-3890590/ Because of the trans adapter the married style shims on the rear of bearing caps and from what I can tell the front output shaft is not shimmed. BTW there is a difference in the married and divorced front output shafts. |
| Bookmarks |
