Old 03-03-2023, 05:08 PM   #1
eric8
Power steering conversion
Hey I’ve got a 77 c10 with factory manual steering. I want to upgrade to power. I’m looking at a nice serpentine belt system that already has the ps pump in the kit.
My question is, aside from plumbing the lines, is there anything else left to this other than buying a factory steering box for a ps equipped truck? Is all else the same between the two trucks? Steering shaft, etc?
eric8 is offline   Reply With Quote
Old 03-03-2023, 06:13 PM   #2
kipps
Re: Power steering conversion
Sometime around 1980, GM switched all these trucks from SAE flare lines to Metric O-ring lines. If you simply buy a 1977 steering gear, you'll have to do more complicated adapting to connect it to the later-model power steering pump.
Buy a steering gear for a 1985-era truck, and use the power steering lines for the 1985 as well. They should work perfectly with the pump on the 1990's serpentine setup.
Seriously consider buying a Redhead steering gear, instead of buying a parts-store steering gear. There is a considerable difference in quality. Redhead boxes have tighter tolerances than cheap boxes, and the result is very noticeable in highway manners.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 03-13-2023, 08:42 PM   #3
eric8
Ok thanks for all the info!
