Old 03-07-2023, 09:08 PM   #326
big_dan
Re: 53 3100 - complete rebuild and upgrade . . . .
Thanks all! Should be plenty of progress in the near future. More later -
Dan
Just playing in my shop, trying to maintain my sanity and maybe finish a project here and there. . . .
My 53 3100 "rebuild" - Soon to be Scott's suspension, LS, low and mean.
https://www.67-72chevytrucks.com/vbo...d.php?t=791886
My 65 Ford project . .
https://www.67-72chevytrucks.com/vbo...d.php?t=792428
big_dan is offline   Reply With Quote
Old 03-08-2023, 08:15 AM   #327
6DoF
6DoF's Avatar
much sexy
6DoF is offline   Reply With Quote
Old 03-08-2023, 08:51 AM   #328
big_dan
One last update - should have the rear together in the next weeks, hanging the tank as well. Using a 15 gallon universal tank from "Tanksinc" with internal pump. Customer service was outstanding with them. Rear will be a 31 spline 9in, Detroit Truetrac with 3.89 gears. With 28.4" tires and 0.68 OD should turn around 2k at 65 - not too bad.
More later -
Dan
Old 03-08-2023, 11:38 AM   #329
dsraven
wow, thats a lot of work that went into the structure back there. should be stiff for sure.
keep postting up those pics, curious to see what thats gonna look like with a diff in there and all connected up.
Old 03-10-2023, 09:47 AM   #330
big_dan
Playing around with hanging the gas tank while waiting for the rest of the rear end parts to show up. One bite at a time . . .
Dan
Old 03-10-2023, 11:06 AM   #331
dsraven
be sure to insulate the straps and anything that touches the tank. I'm sure you have that already in mind.
Old 03-10-2023, 04:51 PM   #332
big_dan
I'll make sure there's no metal to metal, yes. It'll still have to be grounded though.
Dan
Old 03-10-2023, 10:12 PM   #333
dsraven
yep, ground the tank to the frame and the filler spout, at the spout end, to the frame as well. static kills.
ever been at the airport and seen a fuel truck? they ground everything. the vehicles sit on rubber, so insulated from the actual ground, so making a complete circuit from the filler to the tank is essential.
this is a step forgotten by most. good thinkiing on your part.
Old 03-12-2023, 11:24 AM   #334
big_dan
Continuing along on a rainy day so starting assembly on the 9in. True-trac, 3.89 gear, etc. Whipped up some brackets to hold everything still, just enjoying the day. One of my favorite parts. More later -
Dan
Old 03-12-2023, 03:33 PM   #335
57FleetsideC4
It's nice spending time on something you enjoy. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 03-12-2023, 06:04 PM   #336
slammed57
great work! doin it right. lookin good and with a Bass boat in the back, dont get much better than that!
slammed57 is offline   Reply With Quote
Old 03-12-2023, 07:21 PM   #337
Rickysnickers
Rickysnickers's Avatar
I wish I knew how to set up rear gears.
Old 03-12-2023, 08:44 PM   #338
dsraven
thats my favorite diff to set up, so much adjustment is built in.
Old 03-13-2023, 06:27 AM   #339
big_dan
Absolutely. That's why we have this hobby for sure!
Agreed - I love my rig. Got to have sunny day AND rainy day pursuits!
All it takes is practice- dive in! There's tons of literature available and it's rewarding, plus saves $$!
Infinitely better than an 8.8 or Chevy for sure.
Thanks for the input, fellas. More later-
Dan
Old 03-14-2023, 02:04 PM   #340
big_dan
I've been studying EFI for months now. Finally made a decision and had a day off, so made a quick road trip with my Dad to Summit in McDonough, GA and picked it up. Going with Edelbrock ProFlow-4, 550hp kit. Looks nice, will be a little different than the"log" style, and I've always had great service with Edelbrock if needed. Still moving along - thanks for looking-
Dan
Old 03-15-2023, 10:24 AM   #341
Rickysnickers
I have a PF4 and it works really well! I'm sure you will like it.
Old 03-15-2023, 10:34 AM   #342
dsraven
curious, what do you need in the system leading up to that. fuel pump etc?
Old 03-15-2023, 08:20 PM   #343
big_dan
I hope so. Looks to be exactly what I'm looking for.
Nothing fancy - 58psi to the rail. I'll have the pump in the tank, filter and regulator right at the tank.
Thanks for looking -
Dan
Old 03-16-2023, 08:08 PM   #344
big_dan
A few evenings and the 9in is ready to go. Started with a 0.015" pinion shim, set backlash at 0.008", marked it up and it fell right in where I wanted. I've set up a ton of these and was tickled to not have to chase it for days. A little loctite, install the keepers and it's ready for paint. More later - thanks for looking -
Dan
Old 03-17-2023, 09:53 AM   #345
dsraven
nice work.
I like your assembly fixture, looks like ti was cheap and can be re-purposed. haha.
Old 03-17-2023, 12:53 PM   #346
big_dan
nice work.
Yep - most things in my shop have multiple uses!
Dan
Old 03-18-2023, 10:55 PM   #347
big_dan
Still making a little progress. Painted the axle housing and third member, finished mocking up the gas tank and tacked in the upper straps. More later-
Dan
Old 03-19-2023, 09:47 AM   #348
big_dan
And a few more from the weekend. Excited to say this is the first part that's finished! On to finishing up the chassis -
More later-
Dan
Old 03-19-2023, 10:23 AM   #349
dsraven
looks great. did you put oil in it already? if not better tie a string around your finger, wouldn't wanna forget that little step.
Old 03-19-2023, 02:01 PM   #350
big_dan
No oil yet - but I keep a "start up checklist" just for such items.
One last pic / test fit before going on the road for a week - gonna have to relocate that alternator! There's no interference, but it looks gaudy hanging out where it is.
Dan
