Old 03-12-2023, 10:05 PM   #26
crushermechanic
crushermechanic's Avatar
Re: Has anyone built a custom fuel tank
I finally got started on the fuel tank. It's just tacked together right now. I still have to get the filler neck and fittings for the pickup and return
crushermechanic is offline   Reply With Quote
Old 03-12-2023, 10:08 PM   #27
crushermechanic
More pics
Old 03-12-2023, 10:13 PM   #28
Getter-Done
Getter-Done's Avatar
Looking Good
84 Chevy K-20
Old 03-13-2023, 12:32 AM   #29
dsraven
I have built a few tanks in my time. I usually pressure them up a few pounds with air and spray soapy water mix on them, see if anything bubbles. then pressure them up and close the air pressure supply valve. see if the tank pressure drops overnight. like testing a gas line. gotta have an inline guage on the tank side of the air line valve.
Old 03-13-2023, 09:59 AM   #30
leegreen
A safe low pressure way to dry pressure test a tank is to fasten a balloon to one of the lines, pressure the tank to inflate the balloon and see if it leaks down. That will give you about 1-2psi
leegreen is offline   Reply With Quote
Old 03-13-2023, 11:43 AM   #31
dsraven
never thought of that but it makes perfect sense. good one LG.
Old 03-13-2023, 12:28 PM   #32
jwhotrod
Rock valley antique auto makes weld in bungs and filler necks with screw on caps (sealed) to help you with your project. Tanks does as well. I got mine from Rock valley . came with a walbro EFI pump fuel anti starve well and lock ring, return connection and all.
good luck
jwhotrod is offline   Reply With Quote
Old 03-13-2023, 09:35 PM   #33
crushermechanic
My hydraulic shop has stainless weld in an fittings I am going to use. I will definitely leak check it after final welding. Right now it's just tacked together.
Old 03-27-2023, 09:29 PM   #34
crushermechanic
It's finished. All welded out and pressure tested. Now all that's left is a lot of polishing.
