Old 03-12-2023, 07:08 PM   #1
70cst
70cst's Avatar
Need pictures of factory Dual Horns installed
As I continue to add early 70's accessories to my truck ... I have an early 70's NOS Sears Cruise Control that I will be installing ... and I also want to add dual horns.
I have a set of restored dual horns that I want to install.
It came with dual horns initially but sometime long ago they were removed …
Pics of their installed location would be helpful Thanks
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 03-12-2023, 07:29 PM   #2
tim71
tim71's Avatar
Re: Need pictures of factory Dual Horns
dual horns...
1972 Blazer Highlander
1971 GMC K1500 SWB (sold)
2004 Corvette Z06 CE
tim71 is offline   Reply With Quote
Old 03-12-2023, 10:26 PM   #3
70cst
70cst's Avatar
Originally Posted by tim71 View Post
dual horns...
Old 03-13-2023, 12:53 AM   #4
FirstOwner69
FirstOwner69's Avatar
Re: Need pictures of factory Dual Horns installed
Mine. Slightly different angle.
Jim
FirstOwner69 is offline   Reply With Quote
Old 03-13-2023, 06:01 PM   #5
70cst
70cst's Avatar
Old 03-15-2023, 12:16 AM   #6
cericd
cericd's Avatar
My '70 C10 originally came with only one horn but the original core support was already drilled in the spot for the extra horn. If i remember correctly it also has a little hole to receive a small metal protrusion on the factory horn bracket which prevents the bracket from accidentally rotating once mounted. Also, the built in washer on the factory horn bolt is serrated so that it creates a ground so the horn will work.
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 03-17-2023, 08:44 PM   #7
Casper42
Casper42's Avatar
I never, ever understood this oddball option/feature though I've had it on all three of my trucks. why wouldn't a manufacture simply design ONE horn that puts out the tone and level they want. this arrangement is nothing special, by any means.
'72 C10 Cheyenne SWB North Carolina kept for 50 years, 75k original miles, Medium/Hawaiian Blue paint, 3 owners - one for 40 years & garaged kept. Original: sheetmetal, undercarriage, moldings, glass, immaculate unrestored bed.
New - rebuilt engine at 65k in 2015, one frame-on respray in 2010, front bumper, blue houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 03-17-2023, 09:05 PM   #8
70cst
70cst's Avatar
But it was a factory option on my truck which is the reason I want to reinstall.
Old 03-17-2023, 09:28 PM   #9
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Put one horn on, and con people into thinking it doesn't sound right and sell them another horn (or three!) for a price mark-up! It's all about the money. You DO realize that money is why anything is manufactured, right?
~Steven
Simi Valley, CA
Old 03-17-2023, 10:09 PM   #10
70cst
70cst's Avatar
Folks - lets get back on track.This isn't a debate thread. Thanks
Old 03-18-2023, 11:33 AM   #11
dmjlambert
dmjlambert's Avatar
That is interesting. I see the holes on Tim71's radiator core support that would be used for the horn mounted in the position that FirstOwner69 shows.
Old 03-18-2023, 07:18 PM   #12
cericd
cericd's Avatar
Yep, I used a factory horn with it's original bracket and I didn't have to drill any holes.
Chris
Old 03-18-2023, 09:29 PM   #13
halfstep
Was curious about the "dual horn" and "hi/lo" horn references. I thought this was interesting from another post on the forum, FWIW:
"...The horns themselves are identical to those used in most 60s Chevys EXCEPT for the mounting brackets which are unique to these trucks. I don't believe the high note horns were available until 1970. My 69 core support doesn't even have a weld-on nut for the high horn below the left headlight. Also, I've found only one high horn in the junkyards that worked. Most lows have worked. Here's a couple pictures of the horns. The high is on the left. Note that the high has an "H" on it. The low does NOT have a "L".
"...I just checked the 2 from this 72 I'm parting out. The high had a big H in a circle and the low just has a small L in the middle, no circle."
halfstep is offline   Reply With Quote
Old 03-18-2023, 11:11 PM   #14
FirstOwner69
Good points.
When I restored my '69, I replaced the original core support with one from a '71 or '72. I couldn't pass it up when I saw it on Craig's List in perfect condition blasted and primed for $50. I figured I couldn't restore mine for that even though all it needed was paint. My pic above shows the high horn in the correct factory hole with a weld nut on the on the front side.
As halfstep mentioned. I found lots of working low horns but only one or two working highs. I figured that may be due to the horizontal angle of the high horn compared to the low horn pointing down-word allowing the horn to be more likely to "capture" water and rust the diaphragm.
Jim
