Old 03-13-2023, 04:50 PM   #1
ga-stepside
ga-stepside's Avatar
Axles won't go back in
Man, I thought the hard part was done. I removed the c-clips and pulled the axels, no problem. Now that I am trying to put it back together both axles seem to hit something solid about 4 inches from seating. They never seem to enter the spines. The diff is a 12 bolt with limited slip. What am I doing wrong?
1967 C10 Step side
1970 AMX 390
1977 Datsun 280Z highly modified with '95 LT1 power
ga-stepside is offline   Reply With Quote
Old 03-13-2023, 05:07 PM   #2
TATE228
Re: Axles won't go back in
Is the diff. the same diff. that was in it when you took it apart?
-1971 K20 350/sm465
-2004 1500
TATE228 is offline   Reply With Quote
Old 03-13-2023, 05:14 PM   #3
ga-stepside
yes nothing changed, just took the brake backing plates off6
1967 C10 Step side
1970 AMX 390
Old 03-13-2023, 07:07 PM   #4
Jiggers72-GMC
Jiggers72-GMC's Avatar
There's a weld/step inside the axle housing,
push down on the big end of the axle to raise the small end as you push the axle in .........
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 03-13-2023, 07:15 PM   #5
Richard
That thing they are hitting is the carrier. If you are just sliding the axles in, they are just laying on the bottom of tube and will never go in. Put some leverage on the lug end to raise the carrier end up and they will slide in.
Richard
Old 03-13-2023, 07:21 PM   #6
ga-stepside
I kind of tried the lift up thing, I will try it again. Well that took 10 second to get both in. I pulled them back about a foot and pushed down, they moved up a lot, didn't expect that. But they pushed right in.
Thanks a ton guys. I probably would not have slept tonight without fixing that!
1967 C10 Step side
1970 AMX 390
Old 03-14-2023, 03:25 PM   #7
ga-stepside
Okay I am still have an issue with seating these axles. I went out this morning to put the c-clips back in. But after I got the clips in I pulled the axle back to seat the c-clips and install the pin. Now the axles do not go in far enough to touch the seal. The diver side has about 1/4" of shiny metal showing and the passenger side have even more.
1967 C10 Step side
1970 AMX 390
Old 03-14-2023, 03:48 PM   #8
Grumpy old man
Grumpy old man's Avatar
It's always a good idea to post some pictureas of any problem you maybe having , You'll get faster and better information everytime .
Old 03-14-2023, 04:41 PM   #9
ga-stepside
Here ya go. As you can see the axles are right up against the pin in the diff.
1967 C10 Step side
1970 AMX 390
Old 03-14-2023, 04:57 PM   #10
CC69Rat
CC69Rat's Avatar
71-72 axles in a 67-mid 70 housing ?
71-72 axles are longer than 67-70.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 03-14-2023, 05:11 PM   #11
ga-stepside
Oh crap!!!! I have no idea, I would not be surprised. I did not take picture of this before I tore it down, I never saw any grease coming out of the axle tube. Do you know the lengths of these two different axles? Of course, I don't really know if this is a C10 rear end!!!!!! I guess I need to do some measuring.
According to RockAuto 72 is 31 7/16 and a 68 is 30 3/4"
1967 C10 Step side
1970 AMX 390
Old 03-14-2023, 05:17 PM   #12
pjmoreland
pjmoreland's Avatar
That looks normal to me. If you didn't have that 1/4" exposed, then you wouldn't be able to install/uninstall the c-clips.
pjmoreland is offline   Reply With Quote
Old 03-14-2023, 05:26 PM   #13
ga-stepside
Good point.
1967 C10 Step side
1970 AMX 390
Old 03-14-2023, 06:51 PM   #14
Accelo
Accelo's Avatar
Looks good to me.
Accelo is offline   Reply With Quote
Old 03-14-2023, 07:08 PM   #15
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I say run it.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 03-14-2023, 08:13 PM   #16
ga-stepside
Okay I guess I am just a bit paranoid. Trying to work on something I've never done does that to me. Thanks guys I will carry on with this project.
1967 C10 Step side
1970 AMX 390
