Long to short bed driveshaft
Do you guys go to a one piece when shortening your truck?
Posted via Mobile Device |
Re: Long to short bed driveshaft
Yes, go with a one piece.
I put a one-piece on my shortened 69 C10.
1971 Chevrolet K10 - SWB, 5.3LS, 4L60e 1970 Chevrolet K5 Blazer - Project 1969 Chevrolet C10 - SWB, 350 Holley Sniper, 700r4 1969 GMC Suburban - 5.3 LS, 4L60e |
Yes. One piece is sufficient.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71/1977 Jeep CJ5 |
One piece is good but check trailing arm cross member opening clearance if you are lowering the truck.
For those that have shortened their trucks, what length did your driveshaft end up being?
I shortened mine and took some measurements for the driveshaft and came up with 58". Does that sound close?
Somehow, the idiots survive despite their best efforts to kill themselves. - dcozzi |
#6 | |
![]() Join Date: Dec 2013
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 03-16-2023 at 09:49 PM. |
![]() Join Date: Mar 2015
I had a driveline that was hanging around here shortened.
Described at the driveline shop as a cut and weld. A re-balance and I was good. If you are lowering your truck you will have to remove the bracket for the driveline bearing center hanger. I would remove it either way just to be safe. Cheers |
