68 C10 Sport mirrors
There are a couple of threads on here with assembly manual pictures and measurements of where to drill holes for the sport mirrors but they all are for 1971. The previous owner put them in the wrong place and I want to move them. Just checking to make sure before I drill, are the mirror locations the same for 68 to 72? If anyone has assembly manual measurements for the 68 I would appreciate it.
Thanks Jim |
![]() ![]() Join Date: Jan 2005
Re: 68 C10 Sport mirrors
There is a drawing in the assembly manual that shows the hole locations for 67-70 sport mirrors. The problem is that the dimensions are to reference lines, which make them difficult to use. The front mounting hole on both sides of my truck are 2-5/8" back from the front edge of the door, measured along the body line. The top edge of the mirror arm flange is even with the body line.
Roadtrip!
![]() Join Date: Feb 2003
There were no "sport" mirrors in 68 that i am aware of. If you go off the 71 template you should be ok.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
#4 | |
Thanks. The 71 template is close to the aftermarket mirrors I have but not close enough to be certain I'm drilling correctly. I'm planning on replacing the right side mirror with a convex and it will include a template so I'll wait to get it. |
This help ?
71 C-20 07 Magnum RT AWD |
Sorry for the late reply. Thanks for the diagrams. I installed the mirrors in the correct spots but I put a convex one on the right side.
68 C10 Longbed
#9 | |
https://www.lmctruck.com/1967-72-che...n-door-mirrors https://www.holley.com/products/exte.../parts/OMA72RC https://www.speedwaymotors.com/Unite...ck,350061.html |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
The left and right side mirrors locate in different locations! The left side sits closer the front of the door than the right side. The right side locates farther to the rear of the door so the drivers vision of the mirror is not obstructed by the wing window.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
#11 | |
Thanks for the links!
