Old 03-20-2023, 07:01 PM   #1
findog78
AC Delco Corvette Master Cylinder thread size?
I'm doing a rear disc brake conversion on my 69 C10 and looking to mount the new prop valve on the bottom of the master cylinder instead of the side. Searching the web I can't seam to confirm the '82 corvette master cylinder brake line fitting size so I can buy pre bent lines. Some sites say 3/8-1/2 and 3/8-9/16 which I think is my stock C10 master? There is a bracket and brake line set at CJ pony thats say 3/8- 7/16 Inch and 3/8-1/2 Inch? There are also complete kits with master, prop valve (which I already have from my conversion kit), bracket and lines on ebay but I'm weary of fake ACDelco and junk parts on there. Can someone confirm the corvette master thread size please?
findog78 is offline   Reply With Quote
Old 03-20-2023, 08:43 PM   #2
LS short box
Re: AC Delco Corvette Master Cylinder thread size?
I would ask the same question over on corvetteforums.com.
Old 03-21-2023, 07:29 AM   #3
biketopia
Do you have the master in hand? If so go to the parts store and ask to try a few a brake line fittings and confirm. The master I just pulled up on our parts house at work is a Raybestoes MC39052 and shows primary port 9/16"-18 and secondary 1/2"-20
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 03-21-2023, 01:29 PM   #4
findog78
I don't have the master yet. I was looking to purchase as much as possible all at once. I'll go into parts store and check their stock. Thanks though.
