Old 01-31-2023, 07:58 PM   #76
Rickysnickers
Rickysnickers's Avatar
Re: Grandpa's OG 1978
Originally Posted by olrosa View Post
Thanks again lol. I’m not smart enough to figure that out
You're welcome and I' sure you are plenty smart enough to do it. If you can post them, then I know I'm right when I say that. Here's a little help, if you are interested. A couple of guys helped me with this thread, in the area I help moderate. Check it out, it might help
https://67-72chevytrucks.com/vboard/...d.php?t=818026
Old 02-08-2023, 08:02 PM   #77
olrosa
olrosa's Avatar
Starting to install the Holley Terminator X. I am not good at electrical. However this setup so far is pretty easy.
olrosa is offline   Reply With Quote
Old 02-11-2023, 12:07 PM   #78
Hart_Rod
Hart_Rod's Avatar
I could have flown in to help....
Hart_Rod is offline   Reply With Quote
Old 02-14-2023, 02:07 PM   #79
olrosa
olrosa's Avatar
Smile Re: Grandpa's OG 1978
Waiting on you Rob! I am not done... See you Saturday morning LOL
Old 02-14-2023, 04:04 PM   #80
Hart_Rod
Hart_Rod's Avatar
would be fun...
Old 03-05-2023, 03:24 PM   #81
olrosa
olrosa's Avatar
Starting to put some sheetmetal back on.
Old 03-06-2023, 02:04 AM   #82
PowerdbyChevy79
PowerdbyChevy79's Avatar
Looking great... what E-fan kit is that?
The stance is gonna look killer
1966 C10 "Mary"
1967 C10 Custom "Ole Blue"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 03-08-2023, 07:38 PM   #83
Advanced Design
Advanced Design's Avatar
Very nice build! Tagging along. What radiator did you use?
Advanced Design is offline   Reply With Quote
Old 03-09-2023, 03:44 PM   #84
olrosa
olrosa's Avatar
I had a local Radiator shop build the whole setup for me. They used Spal fans. I searched all over for a kit. I like the black stock look. Fortunate to have a great radiator shop in town that can get one foe me. I guess I dont know if they built it or ordered it. Its a 4 row with trans cooler built in.
Old 03-15-2023, 09:02 AM   #85
olrosa
olrosa's Avatar
Wiring is pretty much done. Only have to finish the fans. And start putting this thing back together.
Old 03-15-2023, 12:36 PM   #86
evan
evan's Avatar
Looking great! Are you happy with the location of the ECU? I was thinking about building a bracket to put it under the dash but yours looks like a good fit.
Evan B.
evan is offline   Reply With Quote
Old 03-15-2023, 05:32 PM   #87
olrosa
olrosa's Avatar
Yes I like it there. I looked at under the dash too. But its a tight fit. At least I can get to this if I needed too. Hopefully that is never LOL
Old 03-16-2023, 08:36 AM   #88
Hart_Rod
Hart_Rod's Avatar
Truck is coming out really nice! I'm guessing this one is a keeper? I finally got the motor mounted in mine, but still waiting on some parts.....
Old 03-16-2023, 10:01 PM   #89
PowerdbyChevy79
Ah ok.. Yea it looks like one i never seen.. it looks good though..
1966 C10 "Mary"
Old 03-16-2023, 10:01 PM   #90
PowerdbyChevy79
Thats a good spot..
1966 C10 "Mary"
Old 03-21-2023, 01:33 PM   #91
olrosa
olrosa's Avatar
Rob, I sure hope I keep it. I have a bad habit of selling them when I get bored lol. However this one means a lot to me, so I’m planning on keeping it for sure.
Your truck will be sweet!
Old 03-21-2023, 01:38 PM   #92
olrosa
olrosa's Avatar
Hi all, I got the inner fenders back it. Mild Slosh Tubz. Painted the same satin black as the core support. I’m telling you, it made the engine compartment look really good I think.
Old 03-22-2023, 10:23 AM   #93
Rickysnickers
Flipped
Old 03-22-2023, 12:44 PM   #94
Hart_Rod
Hart_Rod's Avatar
How was the tubz install? Do you have to do any modifications? Was it rubbing before? Thanks and quality work as usual!
Old 03-22-2023, 05:01 PM   #95
olrosa
olrosa's Avatar
The factory inner fenders rubber the tire. That kind of stuff drives me nuts!
The install was not to bad. Like anything when your getting ready to cut a perfectly good part, its a little nerve racking. But it wasn't to bad. I like the fact that they look fairly factory. I did have to trim around my QA1 suspension too. You can see it if you look close.
Old 03-22-2023, 08:07 PM   #96
evan
evan's Avatar
Yeah, I was going to say they look like a better version of a stock fender. The sheen on that black paint is perfect too.
Evan B.
Old 03-23-2023, 11:10 AM   #97
olrosa
olrosa's Avatar
Thank you
Old 03-31-2023, 02:34 PM   #98
olrosa
olrosa's Avatar
Got the hood on and installed the CVF racing hinges. I am not sure if they match the theme of the truck or not. I still have the old hinges too. But these thing do look sweet. And seem to operate well. I have not got them fully adjusted. They are not as easy as I hoped lol.
I am going for a stock-ish look until you open the hood. I have some Coy rally 20’s on order as well.
You can also see how I routed the heater hoses for the most part.
Old 03-31-2023, 05:25 PM   #99
Rickysnickers
flipped
Old 04-01-2023, 12:27 AM   #100
evan
evan's Avatar
Have you thought about spraying the hinges to match the fenders? I bet the shape of them wouldn't jump out at you if the finish matched. Even if you left the shock/spring and hardware raw.
Evan B.
