Old 03-23-2023, 04:32 PM   #26
fatbass
fatbass's Avatar
Re: Still running points?
I loved points dizzys. My old man even showed me how to build up the contact points with solder and shape the surfaces down to the proper thickness/size with jewelers files.
Old southern farmers knew how to make stuff work. I guess it was real conservation in action.
'71 C/20 350/T350.
fatbass is offline   Reply With Quote
Old 03-23-2023, 05:07 PM   #27
OregonNed
OregonNed's Avatar
An old timer told me about using a "thin dime" to set points
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 03-23-2023, 05:11 PM   #28
72SB
Match book was always to "go to" gap tool on the side of the road. Also the strike section of match book to "clean" points.
But electronic ignition came along and most go with that now.
72SB is offline   Reply With Quote
Old 03-23-2023, 05:58 PM   #29
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yep -- I was just about to post that, and you beat me to it.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 03-23-2023, 08:41 PM   #30
davischevy
davischevy's Avatar
For the last several years I have been putting Pertronix modules in my original distributors but I decided to leave the points in the truck I am restoring now.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 03-23-2023, 08:51 PM   #31
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
My 68 had a HEI in it when I bought it, that was the first thing I ripped out and went back to points. I have points almost everything. I have an old Unilite in the show car. My hot rod still has points along with a MSD 6AL box, thing runs perfect. I had more issues and problems with HEI distributors and Pertronix conversions than points with my old stuff, so I just stick with good old points.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 03-23-2023, 09:15 PM   #32
Originally Posted by Stocker View Post
Reading through this thread (and this post in particular) reminded me of something I had long since forgotten. What I just now remembered was that my original ignition did let me down once prior to switching to HEI in 1980. Technically it wasn't the points -- it was the coil that suddenly failed and I was dead in the water. Luckily it happened just down the street from my house so I walked home & got tools, then drove our other vehicle to the parts store.
Yeah, coils go bad at some point. HEIs have coils that go bad also. The '71 wrecker I had with HEI wouldn't start, it had a bad coil. I went to the dealer and they don't have any more. I couldn't believe it, obsolete! I went to NAPA and they guy had a hard time finding one, then finally said "We can order you an Accel or MSD". I said "So can I" and walked out
Unilite!! Ride on. I always ran Mallory distributors and Taylor wires in my hot vehicles. I have a Unilite for my '67s 327.
Old 03-23-2023, 09:54 PM   #33
RichardJ
I have used a paper match book myself. Out on damp night and the engine starts spitting and with nothing but pen knife. Match books used to be easy to find along the side of the road.
I put a HEI in my 67 back around 1990. Freshly divorced, it was the only thing running that I could afford to Insure and I was driving a good distance to work. Changing or cleaning/adjusting the points every two months was getting old.
No other reason to make the change.
For 33 years that coil in cap HEI and the 15 year ago external coil HEI have been running with the ballast resistor still in place.
14 V at the battery and 12 V at the HEI, thank you very much.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 03-23-2023, 09:59 PM   #34
Steeveedee
Who Changed This?
Steeveedee's Avatar
You must have had some other problem. I've had cars with points that went 30k+ miles without even changing the points, let alone the plugs. Then again, my '69 Camaro could eat a set of plugs after a day at the drags. Once I discovered that bad coil wire, that stopped.
~Steven
Simi Valley, CA
Old 03-23-2023, 10:21 PM   #35
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
X2
My guess is he was using cheap points instead of a high quality brand.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 03-23-2023, 10:54 PM   #36
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yep..... I have been lucky, 43 years on my HEI with no failures. But I do have a spare coil in the glovebox, just in case. My local NAPA had it in stock.
- Mike -
RIP El Jay
Old 03-23-2023, 11:02 PM   #37
Steeveedee
Who Changed This?
Steeveedee's Avatar
Originally Posted by 67 twins View Post
X2
Standard Ignition Blue Streak parts FTW! That copper strap alongside the spring was pretty much a genius move. I'll be honest, I have an HEI in my truck, but only because I dropped a lot of money on that Mallory distributor when I had it in the Chevy-powered Buick.
~Steven
Simi Valley, CA
Old 03-24-2023, 12:15 AM   #38
Rust_never_sleeps
Rust_never_sleeps's Avatar
Still keeping as much stock as I can(except for disc brakes), so I'm leaving the points system.
That said, I had no idea what "detached condenser" meant, so they're a bit finicky to gap ;-)
Rust_never_sleeps is offline   Reply With Quote
Old 03-24-2023, 12:17 AM   #39
67 twins
Exactly! I have always used Blue Streak ignition parts & they have never let me down. They are the best parts available as far as I am concerned.
Chris
Old 03-28-2023, 07:09 AM   #40
1972cheyenne454
1972cheyenne454's Avatar
You youngsters still got a thing or two to learn. All this talk of oh look at me and my inability to change? Ya done patting yourselves on the back about how cool you are with your magical electrical wonders? Iffn yall don't mind, I could use some help loading some logs in the tinderbox of my Avery, I gotta re-fill er boiler too. Dag nab it
1972 Cheyenne, 350/th350 12bolt posi, shift kit, 262 Craine Cam, Pertronix HEI.
"When the power of love overcomes the love of power, only then will the world know peace."
"Who are you people and where is my horse?"
1972cheyenne454 is offline   Reply With Quote
Old 03-28-2023, 08:09 AM   #41
At my NAPA store they didn't find one listed, other than performance coils I can order from Jegg's for way less
Old 03-30-2023, 12:17 PM   #42
68 C10 Driver
I'm a points/condenser kind of guy when it comes to my antique vehicles (68 C10, 72 MGB, 64 Mini).
68 C10 Driver is offline   Reply With Quote
