Old 03-26-2023, 08:54 PM   #6
cppursell
cppursell's Avatar
Re: Heater motor fuse popping
Yes I'll do those tests, thank you again! I looked it up and 10a is correct for the blower motor, and I wouldn't want to risk overheating wiring. I hope I can nail this down, fingers crossed.
Originally Posted by Wrenchbender Ret View Post
You shot down my first thought with your second post. 10 amp fuse is not enough for a blower motor.
Put a volt meter on the battery & see what the charging voltage is. It should be around 14 volts. No more then 14.5 & steady with the engine about 1500 rpm or higher.
George
cppursell is offline   Reply With Quote
