Re: My 56 build
you could look for some exhaust gasket sheet and cut your own
you could look for some silicone heat resistant gasket sheet and cut your own I would opt for the silicone sheet personally if you find the exhaust pipe shakes around and causes rattles you could use a flex pipe somewhere close to the exit and then clamp the pipe so it doesn't move so much with engine torque etc, or you could wrap the inside of the trim pieceor outside of the pipe that sits inside there with some silicone sheet just some thoughts, you may not even have an issue with rattling so no use what iffing it to death first. haha. I would insulate the trim part though, paint ain't cheap |
Re: My 56 build
don't under estimate the amount of heat.
I notched the rear bumper on my 67 Tempest for tail pipes and now the chrome starting to discolor. just an FYI
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
