Old 03-27-2023, 09:32 PM   #5
85square
Re: ORD Zero Rate Blocks
Originally Posted by kwmech View Post
One of 2 ways you can go. Buy these and bolt them on or get a similar piece with a centering hole and weld them to the housing. 1'' is the max I would consider for a spacer on the front. Personally, I weld them front and back to the spring perch and leave the spring pack alone.
Not a bad idea. 1” is definitely the biggest I would go too. I’m not too hot on adding anything to the front suspension really but at least these bolt to the spring pack and aren’t very tall.
85square is offline   Reply With Quote
