View Poll Results: If you had the option, which of these grills would you use?
Original 66 painted grill 1 20.00%
64-66 C60 painted grill 2 40.00%
an original aluminum grill that needs to be restored 2 40.00%
the repo aluminum grill that is now available 0 0%
Voters: 5. You may not vote on this poll
Old 02-02-2023, 11:46 AM   #976
TJ's Chevy
TJ's Chevy's Avatar
Re: pdx-sanity66
Looking good! Excited to see paint. Here in Oregon we've been in the mid teens at night and mid 40s during the day. Won't be to warm here till about April.
Old 02-09-2023, 01:33 PM   #977
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
I am really excited to get the painting done. I spent 25 years in Portland, Or. so I'm know the weather up there well. My son flew down from up there these last few days to get some sun. Because of that I haven't been able to get anything done. We did take Sanity out for a short drive. It performed very well for only being driven once before. It was a little rough running but after a few minutes it was running great. Shifting feels good, brakes are working fine, and the new limited slip is working great. It seems to be tracking pretty good but I;m going to get the front end aligned right away.
I did get the front nose of the hood finished up and a final coat of epoxy sprayed. I am also actively looking for a painter.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 03-20-2023, 12:40 PM   #978
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Well, it's been about a month since I posted, I have been keeping up with other's posts. I've been getting some things done along with some other stuff on my to do list. Sanity is licensed, insured, and drivable. I then took Sanity for a 30mile round trip to get the front end aligned. I had no issues at all. The front needed very little adjustment to get it right. Pretty good eyeballing it in if I don't say so myself. I have also got the center console installed. It still needs the inside of the box finished, but it's in. So, I am now waiting for paint, and I need to get a little more driving in before I change the break-in oil. I will also change the trans fluid. During the change I will remove the temp break-in filter and install the temp sender for the trans temp gauge. I have finally got the gaps in the doors set up pretty good for now and I'm still working on my hood. I took the hinges off of the C60. I cleaned them up and they are in great shape. Much nicer than what's on there now. I painted them and they are ready to install.
Sanity'66
Old 03-20-2023, 12:50 PM   #979
Braunschweiger
Re: pdx-sanity66
Congratulations, I'm glad your truck drives so smoothly.
Nice details in the Cab, the rear bumper is great.
I'm also looking forward to moving mine, it will take a while.
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 03-30-2023, 10:47 AM   #980
TJ's Chevy
TJ's Chevy's Avatar
Re: pdx-sanity66
Heck yeah buddy, always a great feeling and motivation when you get to drive them.
Old 03-30-2023, 12:15 PM   #981
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Thank you sir, I decided to adjust the carb and check the timing. I got the carb running better and the timing was a little off so I set that. I drove Sanity to the local monthly C10 get together and it's running very nice, now. The rear bumper is a 68. I personally like the later bumpers., They just look like they belong.I modified the license pat holder to appear it's floating. Just for fun, I added the original license plate frame from the dealer when new. I'll probably change it eventually. I'm also working on back up lights as the new bed sides did not have the holes for them.
Hi TJ, it is a great feeling to be driving my Sanity after all these years.
Another thing Is I have a body and paint guy lined up to paint Sanity while we're in Portland for 6-8 weeks in June and July
Sanity'66
Old 04-08-2023, 02:24 PM   #982
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
I've been driving the truck trying to get a few more miles on it before I do a fluid change on the trans and an oil change I've got break-in oil in the engine and I want to take out the temp break-in filter in the trans and I want to get the trans temp sender installed and get my temp gauge operating.
The truck is running very well now and I'm having a blast driving it. I've also been working on the dreaded side window fuzzies. Ugh!!
Sanity'66
Old 04-11-2023, 03:34 PM   #983
joesscamaro
Re: pdx-sanity66
Glad to hear you're getting to enjoy it even though you're still working on it. Thanks for the update!
joesscamaro is online now   Reply With Quote
Old 04-27-2023, 12:43 PM   #984
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Thanks Joe. I'm having a blast driving Sanity after all these years and it's running real good.
I've slowed down a bit on Sanity right now. It's going in for paint in June so there's not a lot of things left to do until then. I have worked on the bed sides that had 4 or 5 quarter to half dollar sized but very shallow dents in the front part of the bedside that I believe I did while aligning the bed, oops. I have one of the dent pullers that uses glue on tabs that hook up to a slide hammer. This worked great and I was able to remove the dents. I'm ready to spray some epoxy on the affected area and also spray the interior door panels that are also ready.
Sanity'66
Old 05-23-2023, 03:24 PM   #985
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
I'll be leaving for Portland in the middle of June with a stop off in Utah to visit my brother and sister on the way back. While we're gone, Sanity is going in for final block sannding and PAINT. I will be getting progress pictues while I'm gone so I'll try to post some. Stay tuned.
Sanity'66
Old 05-23-2023, 11:15 PM   #986
cwcarpenter98
cwcarpenter98's Avatar
Re: pdx-sanity66
Now that's some exciting news! All the work will soon finally pay off
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 07-22-2023, 01:03 PM   #987
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
We're back from our annual trip up north to Oregon. Sanity is in getting final blocking and paint. I'm going to start on the bed wood finishing while the truck is gone. The heat wave we're having in Tucson is slowing things down. 110+ degrees and monsoon rains. I can get in a couple of hours in early in the morning before the heat sends me into the house and the AC.
Sanity'66
Old 07-22-2023, 01:21 PM   #988
Duncan K
Re: pdx-sanity66
So close! Can't wait to see it painted
66 GMC 910
My Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=754257
Duncan K is offline   Reply With Quote
Old 08-02-2023, 01:17 PM   #989
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
While the truck is out being painted, I have started on the bed wood. I got all of the holes drilled and I'm setting up to start sanding. Another HOT weekend coming up, so my work time is limited. I really need to get some AC in the shop but that's not going to happen for a while.
Sanity'66
Old 08-06-2023, 10:55 AM   #990
clemdaddy
clemdaddy's Avatar
Re: pdx-sanity66
Man, I am with you on the heat thing. It is unbearable. My shop doesn't have AC either but it is at the top of the list. This summer I got hit with 'heat exhaustion', intense head aches, throwing up, 100 degree body temp. All the symptoms for 2 solid weeks. Be careful out there... its real and its dangerous.
Does beer count as forcing fluids? I know, just hoping.
clemdaddy is offline   Reply With Quote
Old 08-06-2023, 04:14 PM   #991
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
I know exactly what you mean. I try to get out early enough to a few hours in but by noon it is 100+. We've had more than a week of 110. Make sure to drink lots of water or other liquids of choice. I got a 30 in. pedestal fan pointed directly at me.
Anyway, Sanity is being prepared for paint. The bed is ready and Bryan is working on getting the hood blocked out, plus other stuff. I'll try to post some progress pics later. I've been working on my bed wood. I've got all of the holes drilled in the 4 edge boards and the next 2 boards that have the holes drilled for the inner fenders. I then went ahead and wiped them all down with grease and wax remover before sanding them on all sides and ends with 220 grit sandpaper and slightly rounding all of the sharp edges that might splinter. I then sanded the top sides with 320 grit sandpaper. Except for a final wipe down, they are ready for the first coat of finish. The bed wood is from Mar-K and it is high quality and needed very little sanding. I'm very happy with choosing white oak.
Now I've got 6 more full length boards to do the same thing with.
Sanity'66
Old 08-11-2023, 12:52 PM   #992
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
I've got the first pictures of Sanity's paint. The bed and hood are done. He'll be working on the cab & fenders next. The front grill and bumper are back from powder coating.
Sanity'66
Old 08-11-2023, 01:19 PM   #993
Braunschweiger
Re: pdx-sanity66
It's going to be great, it's mighty warm where you are.
Here in northern Germany we had a lot of rain and a maximum of 20 degrees/ 68 degrees Fahrenheit in the last few weeks, today it's sunny and warmer.
I look forward to seeing your finished truck.
Greetings Harald
My 62 build thread
Old 08-11-2023, 09:06 PM   #994
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Thanks Harald, it's been tough getting things done. Today was the first day in a record 63 days that it didn't hit 100 deg. and a bunch of 110+ days. If I can get up by 6am I can get in a few hours. I am about ready to start applying the oil-based spar urethane over and over again with sanding in between. Now that I'm seeing the paint color I think the bed will look great (I hope).
Sanity'66
Old 08-15-2023, 07:48 PM   #995
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
I'm so happy today! The front of the truck got sprayed today. These shots show the color much better.
Sanity'66
Old 08-15-2023, 10:10 PM   #996
Arne
Arne's Avatar
Re: pdx-sanity66
Nice!!
The green is a little lighter than mine, just as you said some time back. I like it!
- Arne
Finished Project - 1964 C10 Stepside, mild restomod
覧覧覧覧覧覧
Arne is offline   Reply With Quote
Old 08-15-2023, 10:15 PM   #997
Turtleman
Turtleman's Avatar
Re: pdx-sanity66
Looking Good
Are you going to be back together in time for Gino's GitDown?
Turtleman is offline   Reply With Quote
Old 08-16-2023, 02:38 AM   #998
Braunschweiger
Re: pdx-sanity66
Oh that's very pretty, I like the color.
Greetings Harald
My 62 build thread
Old 08-16-2023, 02:35 PM   #999
joesscamaro
Re: pdx-sanity66
Looks very nice and I'm sure you're pumped! Congrats on getting it to this point!
Old 08-16-2023, 05:36 PM   #1000
collins10672
collins10672's Avatar
Re: pdx-sanity66
truck looks nice.i like the color.you did a fine job on the metal work too.
collins10672 is offline   Reply With Quote
