Old 03-31-2023, 05:41 PM   #1
Yamariv
Yamariv's Avatar
250 6 Cylinder to SBC 350 - Do you really need to change fuel lines to 3/8's?
Just curious if anyone has actually had any issues with using the smaller 6 cylinder stock 5/16th's fuel lines when upgrading to a SBC 350? My understanding is the 350 or larger engined trucks got the bigger 3/8's fuel lines?
1971 Chev C10 - 250ci L6 w/3 speed on the floor
Upgrades: Power Steering
3 Core Radiator
7 Hole Gauge Cluster
Power Brakes (Incoming!!..)
1971 350 (Incoming!!..)
Yamariv is offline   Reply With Quote
Old 03-31-2023, 06:59 PM   #2
pjmoreland
pjmoreland's Avatar
Re: 250 6 Cylinder to SBC 350 - Do you really need to change fuel lines to 3/8's?
I've had two trucks that I converted to a 350 and still had the 5/16" line. Both 350s were in the 300HP range, and I didn't have any fuel starvation issues. I ran mechanical fuel pumps in both cases. I'm not saying it's the best way to do it, but in my case it worked.
pjmoreland is offline   Reply With Quote
Old 03-31-2023, 07:17 PM   #3
geezer#99
geezer#99's Avatar
I ran this dual quad up past 120 several times using a stock pump and 5/16 line.
And later a 750 vs Holley up to 7 grand thru 3rd gear.
geezer#99 is online now   Reply With Quote
Old 03-31-2023, 07:57 PM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
OK, it was only a 283, but my '64 Malibu with a 283 got to 120 (indicated on the speedo) with the 5/16" line. I did put a 4GC Rochester and dual exhaust on it.
~Steven
Simi Valley, CA
Old 03-31-2023, 10:10 PM   #5
jumpsoffrock
Even if you had a big block 1 ton truck fully loaded GVWR, going up a steep incline at full throttle with engine at redline speed, I wonder if you'd need the 3/8 line.
jumpsoffrock is offline   Reply With Quote
Old 04-01-2023, 08:26 AM   #6
I changed mine to 3/8" because of matching hard line to fuel pump. I didn't have any 5/16 that would go into the V8 fuel pump I had. Don't know if that was something weird on my part or ??? I have done several with friends where they kept 5/16 and ran it for MANY years without issue
Old 04-01-2023, 09:07 AM   #7
72SB
GM used 5/16 on 6 cyl and 2 brl V8 motors. 3/8 on all 4 brl V8's.
FWIW I had a 2 brl V8 5/16 set up. When I put in a 411 hp motor, I swapped to 3/8" as the 3/8" fuel pumps put out more than a 5/16 fuel pump.
I am not a GM engineer but play one on TV...so I assume GM had their reasons for specking 3/8 fuel line
With that said several people still keep the 5/16 apparently without issue....or at least none they know of.
I got Right Stuff tank to pump pre-bent line
72SB is offline   Reply With Quote
Old 04-01-2023, 09:24 AM   #8
Yamariv
Yamariv's Avatar
Thank you very much guys, this is exactly what I needed! So no point in preemptively changing out the lines, thanks!
3 Core Radiator
Old 04-01-2023, 10:16 AM   #9
You only need to change to 3/8" fuel lines for a BBC 350
Old 04-01-2023, 10:27 PM   #10
'68OrangeSunshine
'68OrangeSunshine's Avatar
On the 350 Big Block, do you have to buy a 396 bare block core and sleeve it down?
Old 04-02-2023, 12:06 AM   #11
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
No, no no. It's a destroked crank & special pistons.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 04-02-2023, 05:06 AM   #12
'68OrangeSunshine
Like That Other Manufacturer's 351 Cleveland?
Old 04-02-2023, 05:51 AM   #13
I was just joshin'. That's why the LOL emoticon. I find it humorous to be adding SBC when speaking of a 350. Thought I'd give a poke. I guess the 366 would be a good candidate if someone wanted to build a BBC 350, for whatever reason. When I think big block I think go big. I love the idea of playing with displacement in SBCs. Ever seen a 283 crank in a 400 block? Special main bearings required. A whole lotta meat in those bearings! But boy does that mill scream. To the tune of 500 hp!
Old 04-02-2023, 09:42 AM   #14
Sheepdip
Sheepdip's Avatar
This might put your mind at ease
https://help.summitracing.com/app/an...e-do-i-need%3F
Sheepdip is offline   Reply With Quote
Old 04-02-2023, 01:23 PM   #15
Yamariv
Yamariv's Avatar
Originally Posted by Sheepdip View Post
Nice, thanks!
3 Core Radiator
Old 04-02-2023, 02:38 PM   #16
54blackhornet
54blackhornet's Avatar
I was taught to not install a filter before a mechanical type fuel pump ?
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 04-02-2023, 03:24 PM   #17
72SB
I believe the Summit link noting to put a 100-micron filter between the pump and tank was referring to a Electric fuel pump placed near the fuel tank
Mechanical FP, yeah filter goes between FP and carb
Old 04-02-2023, 03:25 PM   #18
'68OrangeSunshine
Yeah. I knew it was an April Fools gag, I just wanted to see how deep the BS went. FoMoCo did exactly that with the 351 Cleveland. While the 351 Windsor was a regular run-of-the-mill SBF, the Cleveland used a big block and was underbored to use small block components, making a high performance engine.
At least I think that was it. Not really a Ford guy.
Old 04-03-2023, 08:46 AM   #19
^^^ All I know is Ford making three 351s in the approximately same time period did nothing to help their already confusing parts compatibility issues. Which 351, C, W, or M? Are you sure it's not a 352? I never knew that about the Cleveland. That's how interested in Fords I ever was
Old 04-04-2023, 01:01 AM   #20
'68OrangeSunshine
Not a Ford guy either, but my mechanic is.
