Old 04-07-2023, 12:49 PM   #5
jeffahart
jeffahart's Avatar
Re: Dana 44 Closed Knuckle Axle Shaft U-Joint Part Number
Originally Posted by Chaparralman1974 View Post
Ok, so I ordered the new ujoints for the axle shafts. The original ujoints did not have the seal on them as it is all lubricated from the special sauce that lives in the knuckle cavity. The new ujoints have the seals on them. Do I have to remove the seals, or just let the permalube idea take care of itself?
Funny the things that make you scratch your head.
Here's my take, I'd leave them on. They're more than just dust caps. Think of it this way. I used to have an old paint brush spinner. I would stick the brush handle in it and stick in a empty buck and it would spinn the excess paint off the bush bristles.
If you stuck a joint without the seal, let's say a driveshaft. It would be exposed to dirt sand and the likes. But.. would it spin the grease out of the joint trunnion?
If it's inside, will it take on grease, or lose grease, or neither.
For me, the low hanging fruit is leave the part as shipped and install it.
Good luck; and have fun!
j
White K20
jeffahart is offline   Reply With Quote
