Gauges
My temp. gauge is not working. It appears that the wire going to the sensor got too close to the manifold. I first plan to replace and re-route the wire, but if that doesn't work, I will probably have to replace the gauge.
Can the temp. gauge be replaced by itself, or does it require changing the entire cluster?
Hook'em |
Embrace the Redneck
you can replace the guage itself w/out replacing the cluster
sswj, i think i might have one ..... i don't know if it or they work or not sswj
'01 Camaro Son, you just can't get there from here... |
Black 72 Chevy
Guage it selft can be replaced.
Thanks for the information. I still hope I can fix it without changing out the gauge, but we will see.
Hook'em |
Is a bullfrog waterproof?
Those gauges are usually pretty forgiving. The wire on my 86 Suburban did the same thing after the engine was rebuilt (not by me). I just cut out the burned part, soldered in a new wire with heat shrink and it worked fine. There is a web site where you could buy the new shunt to go on these gauges and a lot of other gauges for other vehicles. I think it was called Fix-A-Gauge.
![]() Dave
"It is better to remain silent and be thought a fool, than to open one's mouth and remove all doubt." Ben Franklin __________________ 1970 Chevy shortbed 2002 Harley Custom Chopper (Long sucker) 1998 K2500 5.7L 5-speed Longbed 1st two are My son's toys...they just live in my garage! 1997 GMC K1500 Suburban 1993 S-10 Blazer 4D (youngest son's daily driver) 2000 Dodge Ram 4WD Ext. Cab (5.9L) Wife is a late year 1951 |
Franko72
mine did the same thing, I just spliced another wire and re directed the route and it worked fine.
![]() 1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach My Home Page Better to burn out than it is to rust |
