Old 03-29-2023, 07:12 PM   #101
FamilyTruckster65
Re: 65 C10 Family Connection
Well, remember those cool wheels that I got over 20 years ago? They take 14mm lugs. These rotors have 1/2" screw in studs. Sooo....
FamilyTruckster65 is offline   Reply With Quote
Old 03-30-2023, 07:01 PM   #102
FamilyTruckster65
Using an Astrovan hydrobooster and needed to mate the rod to the 65. You can see the Captain Fab bracket installed on the booster.
Old 04-01-2023, 11:58 AM   #103
FamilyTruckster65
PSA. Keep your windows closed, a squatter has moved in.
Old 04-04-2023, 08:01 PM   #104
FamilyTruckster65
Test fitting the 67-72 rear bumper. I will be installing a hidden hitch also. She still needs to be able to be used like a pickup.
Old 04-09-2023, 07:58 PM   #105
FamilyTruckster65
More fun stuff arriving. Fat 67-72 wheel houses.
Old 04-09-2023, 10:26 PM   #106
Getter-Done
Getter-Done's Avatar
Those fat wheel houses are going to make the rear look Wide
Nice addition
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 04-11-2023, 03:36 PM   #107
joesscamaro
Are those wheel tubs a bolt in option for our trucks? They look quite a bit wider than our factory tubs.
joesscamaro is offline   Reply With Quote
Old 04-11-2023, 07:50 PM   #108
FamilyTruckster65
Well...for sure the flange on the floor is in a different spot, so some massaging will have to be done there.
As for the flange on where it bolts to the bed side, I will be moving the wheel house upward due to being lowered. I will be redrilling the holes in the bedside. I can compare the flanges of the widened tubs to the stock ones for you. I will post pictures when I do.
Old 04-11-2023, 08:14 PM   #109
FamilyTruckster65
Working on the radiator and core support and figuring out what I need to do. This is a "universal" radiator. Since in am using an L86 with the stock accessories both radiator fittings are on the drivers side. This radiator is a cross flow unit with an internal transmission cooler. The radiator was intended to have both fittings on the passenger side. So I flipped it around to have them on the drivers side while moving the trans cooler fittings to the passenger side. To do this required that I move the filler neck to the opposite corner.
Old 04-13-2023, 08:24 PM   #110
PowerdbyChevy79
PowerdbyChevy79's Avatar
Loving the progress
1966 C10 Mary
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1976 C35 Sierra Grande "Mr. Harvey"
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
1982 C10 Silverado "Lucy"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 04-15-2023, 10:02 PM   #111
FamilyTruckster65
Thank you 79.
Today's project was getting the new rear axle housing prepped for installation. I need to weld on new saddles for mounting to the trailing arms. Question is, how far apart should they be? I can't tell you, because I cheated.
Used "from unders" tack welded to the saddles to jig it up on the original 12 bolt. Now I can just center it up on the new housing. No measuring.
Old 04-18-2023, 08:37 PM   #112
FamilyTruckster65
Popped the original windshield out as it was delaminated and broken. I was pleasantly surprised to find zero rust.
I was laughing to myself when I looked at the tag on the replacement windshield. I have been hoarding parts for a while. I found the receipt for the windshield when I got it from The Filling Station, in 2003... Does that make it a vintage part??
Old 04-18-2023, 11:05 PM   #113
Getter-Done
For sure that is vintage .
I see a 1980 or 1990 vehicle going down the road and,
That is Not old to Me
That Windshield is NOS 50 %ish
84 Chevy K-20
Old 04-20-2023, 03:38 PM   #114
JohnIL
JohnIL's Avatar
[QUOTE=Does that make it a vintage part??[/QUOTE]
Your new windshield is almost an antique!
1965 C10 Long Bed Fleetside
SBC 350 and Saginaw 4 Speed
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=838676
JohnIL is offline   Reply With Quote
Old 04-20-2023, 07:38 PM   #115
FamilyTruckster65
Yeah, I got it when I did not have a belly but I did have hair!
Old 04-22-2023, 11:30 PM   #116
FamilyTruckster65
starting to get the bed mounted. is this a problem? Well, besides the sideways picture..
Old 04-22-2023, 11:51 PM   #117
Arne
Arne's Avatar
Hmm. That could be a problem. I guess you could narrow the axle...
That's one of the reasons I ditched the 10" wheels that came on my truck.
Name:  Screen Shot 2023-04-22 at 8.51.04 PM.jpg
- Arne
Finished Project - 1964 C10 Stepside, mild restomod
覧覧覧覧覧覧
Arne is offline   Reply With Quote
Old 04-23-2023, 08:16 AM   #118
Getter-Done
Flip for ya.
Yes those will rub when the frame flexes in the curves.
84 Chevy K-20
Old 04-26-2023, 01:40 PM   #119
FamilyTruckster65
So this rear axle is from a 1970 F100 and it is 2" narrower than the factory 65 axle. With my wheel and tire combo it is still too wide for the ride height I want to achieve. I have had these wheel for more than 20 years and I am not going to get differnt ones.
The lower (or second) picture shows the truck mocked up at ride height. Currently I have 3" of upward travel to the bumpstops on the rear axle. First picture shows suspension at full compression, or on the bump stops. There is 4" of droop from ride height. 7" total axle travel. I am using air bags and have a ride height controller.
I would have approximately 7" from the lowest part of the frame under the cab to the ground at ride height.
Gonna have to get out the chop saw and make me a skinnier axle!
Old 04-26-2023, 08:35 PM   #120
Arne
Arne's Avatar
This is a great build. I wish more people would start using the "Rate this Thread" so that threads like this get the 5 stars they deserve.
- Arne
覧覧覧覧覧覧
Old 04-27-2023, 07:09 AM   #121
joesscamaro
How much more narrow are you going to go...a couple of inches? Thanks for posting the progress!
Old 04-27-2023, 07:43 PM   #122
FamilyTruckster65
Pretty sure gonna do 1.5" per side from where I am now. So that would make it 58" wms-wms. Stock width pretty sure is 62" wms-wms.
Oh, and I lied earlier. The 1970 F100 axle is 61" Numbers are so confusing...
Old 04-27-2023, 10:16 PM   #123
duramax55
familytruckster have a question if you only take 1.5 inches on both sides ca you still keep the same axels? will you cut 1.5 off of each side just wondering??
duramax55 is offline   Reply With Quote
Old 04-27-2023, 10:40 PM   #124
FamilyTruckster65
Well in my case I cannot do that with these parts, there would not be enough spline left. The stock shafts are a smaller diameter at the end of the spline, thus not allowing me to respline them. So all the work earlier of welding up the holes and redrilling the pattern to 5x5 will go unused.
I have a pair of new axle shafts that have extra long splines and are intened to be cut to length. Maybe not as trick as having axles custom made, but still useable for what I am wanting to do.
I will make the cuts to the axle housing so as the pinion will be centered not the pumpkin. I need to keep the driveshaft away from nearby bits.
Old 04-27-2023, 10:45 PM   #125
FamilyTruckster65
This is the type of axle I am using.
https://www.speedwaymotors.com/Speed...le,418891.html
